I have a very rare RS Stagea for sale with 75,000 genuine kms that's had over 10K spent on mods (receipts available).
Full luxury pack with sunroofs, woodgrain, leather heated electric seats, TV etc
Mods are as follows.
1. Hi-flowed turbo.
2. Spitfire coils.
3. Blitz plumb back FMIC.
4. Haltech interceptor programable ECU.
5. X-Force split dump.
6. X-Force Hi-flow cat.
7. Fujitsubo 3" catback exhaust.
8. Haltech boost control solenoid- electric wastegate controller.
9. Custom towbar fitted.
All of the modifications have been carried out by Tweakit Performance. No expense has been spared in modification and maintenance.
Oil has been changed every 5000kms, brand new tires, brand new pads with machined disks.
200 rwkw was the first run on the dyno, with airflow controller it will easily produce 230.
No accident history and car is in immaculate condition, other than a couple of very light stone chips.
This car is perfect for road trips, town driving or doing trackdays.
Included extras are towbar as mentioned, roofracks and cargo net.
$20,990ono
Located in Sydney
Feel free to call me with any questions, Sam 0417 664 077
Photos will be up soon, sorry my ex got the camera :(
Edited by Stage Flight
  • 4 weeks later...
how much for the girl how many k's she got on her shaved or unshaved could be interested at rite price
bump 4 nice stag haha
Buy the car and you'll find out...
swap you a 4" Apexi zorst for your Ex.
Head down to Bondi and look for an asian hardbody sporting a SAU tat on her belly.
You can drop Apexi zorst at my place on the way.
  • 3 years later...
1. Hi-flowed turbo.
2. Spitfire coils.
$20,990ono
Located in Sydney
Reluctant sale $10500, come get an absolutely glamourous 2ooKW 2WD monster for a bargain.
Ping me on SAU or SMS the number above. Speak soon, cheers Sam
Don't miss out on this sweet tourer / daily drive.
Photos final, sorry about the delay.
The last one's the ex. You can have her too!
What is the tow bar rated too?
1.5 or 2 Tonnes, I towed a mates ski boat once with it, auto and torque loved it. What are you after?
I have a RS my self but no tow bar, was interested to know. Would you sell it on it's own?
What do you plan on towing? Yeah I'll consider it if you find someone interested in RS without towbar.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
