Hey guys just a few questions ive just ordered a wolf 3dv4plus for my r33 and i have a few questions for the install. basicly from what ive seen in the DIY you need to install a air temp sensor and a air line to the back of the wolf (air line is for MAP or somethin to disconect AFM) just wondering if these are needed(not that air line is a worry). The only thing im a bit iffy about is wiring the air temp sensor in. If someone could dirrect me to a page or give me some pointers on wiring this in without connecting dirrectly to board.
https://www.sau.com.au/forums/topic/236246-wolf-3d-v4plus/
What is the rest of the engine combination? Turbo, manifold, exhaust, injector size, fuel system arrangement and pressure etc?
Yes air temp is useful but to a degree it depends on where you live as well, how much temp variation you get from one day to the next etc. You can do a lot of a tune around the sensor, but where its particularly useful is helping get around heat soak when starting.
Give me the rest of your info as above and i'll paint a better picture.
https://www.sau.com.au/forums/topic/236246-wolf-3d-v4plus/#findComment-4136629
does anyone know what there worth? i just upgraded to a wolf v500 and i want to sell my v4 r32/33 plug in.
The V500 is worlds better than the V4, i do ALOT of Wolfs now, i reckon you could get about 500-650 for the V4..... seems to be the going rate.
https://www.sau.com.au/forums/topic/236246-wolf-3d-v4plus/#findComment-4137736
It's not there to measure the ambient air temp. It's there to measure the temperature of the air going into the cylinder. Particularly after it's been through the compressor housing. Even if you have a very good IC, the air will still be several degrees above ambient.
https://www.sau.com.au/forums/topic/236246-wolf-3d-v4plus/#findComment-4138657
The reality of tuning without air temp input is that your tune may vary .2 of an AFR. Its enough to make a diference for your light load tunes for economy but you wont pick it in throttle response, or on full power. Turning on closed loop operation with a narrow band sensor and you probably wont even notice the diference. Most ecu's ive tuned i aim for a 15 - 15.5:1 light load AFR anyway, so its still better economy than the 14.7 the closed loop mode tracks too.
Where air temp compensation is very useful is allowing the car to start easily when its heat soaked. Eg.. driven so the cooling system is up to 80 degrees, and then parked in the sun for 20 minutes. The intercooler soaks up heat from the radiator as does all the intake piping and intake plenum. Allowing an extra % enrichment in this situation makes the diference between being able to start the car and not being able to start it at all. Ive seen 75+ degree intake temps when starting my car after its been parked like this.
All my tuning has been done in the tropics where ambient air temps during the day are around 55-60 degrees at the plenum. 70+ on boost. Ive seen maps from gtr's tuned in melbourne and they start their air temp compensations around the 40-45 degree mark. Perhaps the cooler states use the compensation differently...? I'd love to have the intake temps the lower aussie states get.
Edited by Vspec R33
https://www.sau.com.au/forums/topic/236246-wolf-3d-v4plus/#findComment-4138692
i drove cats RB26 from wangaratta to campbeltown in NSW to run the engine in (12am to 6amish) average intake degrees on datalogger was 9 to 10 degrees C..... gotta love GIZZMO phenolic intake gaskets :)
https://www.sau.com.au/forums/topic/236246-wolf-3d-v4plus/#findComment-4139186
When i was in melbourne about 2 months ago I thought it was cold... then it started to snow. The only time we ever see air intake temps like that is in winter, on the tabelands around 2am when the dew is stating to fall. Ive heard of 4 degree intake temps off boost. Easily another 30-40hp gained from a 40-45 degree air intake temp drop.
Uras? your a wolf dealer are you, or are you just installing and tuning them along with everything else ?
https://www.sau.com.au/forums/topic/236246-wolf-3d-v4plus/#findComment-4139216
Nah but i get alot of tunes come in from other places. Maybe cause WOLF is local (melb) there is alot around. At the moment i do 2- 3 week. The only thing dont like is the Cold start it is evil on them (v4) ... prick to get right.
https://www.sau.com.au/forums/topic/236246-wolf-3d-v4plus/#findComment-4139231
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
