Hi,
Just wondering what people have done with their R32 gtst rear quarter windows when having their car re-sprayed. I just priced some from Nissan, and because the window and rubber come as a single unit, theyre about $1000 + GST for both sides.
Has anyone removed the windows without damaging the rubbers and replaced them after having their car sprayed?
Hi,
yes
yeah I made them remove and replace mine, but my advice is if your seals are fine then just leave them in and get them to back mask it properly. mine went in an out 'ok' but I think it's far better to just leave them in if they aren't old and crusty.
Your rubbers cant be in any worse condition than mine were and we didnt damage mine at all when they were removed and replaced.
I got some local glass company to do it for me...i dont trust myself with glass :)
mate i got a r32 GT-R and re sprayed it recently i tell u what man all comes down to who is doing your car 110% if someone with years of experience is doing it and is good at what he does then you can leave the quarters on like i did and they will easily be able to put tape on the seals perfect and spray it and it will come out mint and on the line like mine did no need to spend the extra money to get someone in to take them out then put them in waste of money waste of time.
I've just finished painting an R32 and we left the rear quarters in at the owners request. It looks good, and since we kept the same colour anyway it's difficult to see it's only been taped.
However, I'm now doing mine and for the sake of a $40 removal fee I figured I may as well get them professionally removed, especially since I'm changing the colour. The rubbers remained in good condition after removal. Not sure how much it is to reinstall them.
If you do get them removed and they haven't done an R32 before, watch out for a clip at each side located at the back of the window down the bottom corner, it can be easy to break.
  • 1 month later...
Hey SAm,
I would like to know where you got them removed for 40 bucks and is it in melbourne?
I will be painting my 32 some time in the future and really would want them out as the last time it got done it was masked.
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
