How ya goin fellas
a couple of weeks ago i posted a message regarding my frontkit. Ive prety much fixed it now thanks to R33AzzA. i've so far managed to put the bodykit back by taking out the mudguard and fiddling with the screws that hold the kit in place. NOW i have 1 more problem, the plastic clip wich holds the kit up was snapped during my collisioin wit a 4WD, anybody know where i can buy a new clip?
see my attached pic!
cheers ppls
sau_pic.doc
https://www.sau.com.au/forums/topic/236280-help-with-front-bodykit-please/
I dunno where you can get a new one, i just installed my new front bar and i didn't use those, i just got the clips from supercheap that have a square base and a round head (panel pack) so a screw can make a thread and just screwed it in. maybe you could try that?
  • 1 month later...
hey man ive attached the msg u sent me just to refresh ur memory. The msg below was ur advice to me regarding my post on the forum. Anyways mate do u no wat section that 'clip' is under in supercheapauto, or even beta if u remember wat its called exactly so i can go n ask the shop assistant for help!! thanx mate
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
