Were they run on the same dyno??
Yes, exact same dyno. Dyno Dynamics in Shootout mode.
and the 468rwkw one has run 132mph.
Can you post sheets please? Will help a lot of people decide if the HKS turbo is worth the 2k more...
  • Replies 58
dirt can you post up bp98 tune as well because i want to see comparison of hks t04z with garrett t04z on same fuel
mine made 428rwkw on 24psi (garrett) and another has made 468rwkw on 25psi (garrett). both were standard stroke 2.6l's
is this a 2.6l?
Yes still 2.6 & it made 422rwkw on 22psi & was on synergy8000.
my hks t04z has gone 585rwhp (440rwkw from my calculation) on 18psi on 98 pump fuel on a very very low reading dyno, another brand new dyno dynamics one i went on recently read 40hp more (520hp to 560hp) on lower boost tune, so i reckon it would of been a bit over 600rwhp on any other dyno.
brad!!!
clearly you should know you had about 150rwhp of timing in that tune to make that power
PING IS POWER
actually it was a different dyno i think, cause my car was tuned on the new 4wd dyno (in 2wd) and chookos was on the old 2wd one
chookos made 454rwkw or 608rwhp with similar tune to mine, but made more with cam timing and further tuning. my cams never got moved from zero so may have been a little more in it!
same tuner, same workshop, same fuel and very similar engines etc etc
ok, could my standard valve springs and 260 poncams be limiting my power on 24 psi with a t04z to 376awkw (.84 split a/r ex housing)..???
Just a little bit, Dave. :bunny:
PS, I'm still waiting!
interesting for me, that youve only run 132mph with 460rwkw. Ive seen an r32 gtr with 360rwkw go 134mph @ 10.8
brad!!!
PING IS POWER
lol Simon, he has never done a power tune on my car only a run in tune on the first motor years ago ;) everyone knows he wont touch an autronic ecu hence why i never used him in the end.
Edited by unique1
Simon's time (10.91 @ 132 with 460rwkw) was with a stock gearbox and $90 shitty tyres.
At 3256lbs (std 32 GTR weight) and 485hp (360rwkw) you shouldn't be running 134mph, more like 124mph.
Can I ask what turbo was used?
Let me guess, it's a 700+hp rated turbo, running in its peak efficiency, and "only" making 485hp at the treads. I'd suspect a very low reading dyno....
Besides the point, all I want to see is a compo between a HKS T04Z and Garrett version, someone post dyno's!!
something im struggling to believe unless it was a super low weighted car with a dog-box on slicks and with that ET i doubt it.
134MPH = at the very least 400AWKW in a R32 GTR
im pretty sure he ran around 134mph on another pass...
he was also running standard box so change from 2nd to 3rd was slower than leasurely which would have dropped the mph a fair bit i would imagine.
GRRRRRRRRRRRAAAAAAAAAAAPPPPPPPPPHHHHHHHHHHHHHHHHHHHSSSSSSSSSSSS
r32 gtr, os giken gear set, hks t51r. Not sure if it was lightended, il have to ask him next time i see him.
another r32 gtr with n1's went hi 11s @ 125mph, he had just over 300rwkw. Wasnt a fancy set up either.
My boat did 139.67mph with 456 rwkw although only 10.70 with 1.57 best 60 foot. It had 540 pound springs at the time in rear, yes way too hard and wouldn't weight transfer, and front diff not there.
PS Good power Dave and good result. PPG helical dog box would have less power drain I guess over stock synchro box??
Edited by Boosted Zed
LOL
HKS T51R... SPL or KAI? Either way its a ~900hp rated turbo, and you reckon it only makes 450rwhp.
Either it's being transfered through a rubber driveline or it's running 14psi.
As I said, thats one hell of a low reading dyno. It's physically not possible for a car that weighs as much as a GT-R to do ~135mph with 450rwhp.
No they would be about the same...the gears are the same basic design albeit a more agressive tooth profile and far superior parent material on the PPG. The way each gear is selected whether it be dog engagement or synchromesh has little bearing on the losses after the gear is selected.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
