Alright i know it has most likely already been covered a thousand time's but here it goes again. i Have a R34 GT25T 2dr manual. just wanna know how much oil goes in the tranmission and diff. I have heard about 3.6l in the transmission and Just under 2L in the diff? can anyone confirm this?
All so what type of weight oil. I am taking a guess for trans a 80-90 GL-4 and for diff a 80-90 GL-5 or similar as this seems to be more or less the same as all nissan's run from the factory up till about 94 (can't find a genuine nissan fluid chart for any of the newer cars) R32 and Z32 run the same spec oil as i have mentioned above from factory so it's a safe bet.
And LSD additive worth putting it in a STD viscous diff? i am planing on use a FUCHS titan Gear HYP oil and they say it is perfect for STD and LSD with no additive needed?
https://www.sau.com.au/forums/topic/236300-r34-gt-t-oils/
diff takes about 2L
and gearbox is around 2.2-2.4L
thanks for the info. not that i don't trust you i just like to be well informed so can anybody else confirm? if not i will just work off what dori32 is telling me
https://www.sau.com.au/forums/topic/236300-r34-gt-t-oils/#findComment-4159734
  • 2 months later...
just thought i would let you's all know how it went. gearboc take a bit over 3L and diff takes about 1.8L. out of a 5L only bout 100ml left
https://www.sau.com.au/forums/topic/236300-r34-gt-t-oils/#findComment-4296600
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
