RB25 Parts
Alternator / aircon compressor / starter motor $50 each
R33 Airbox with filter $40
R32 GTR parts
STD 05U turbos x 2 good condition (replaced with 517z's) $400 pair ONO
STD dump pipes x 2 $50
Trust MX front pipe $200 (2 1/4 into 3 inch)
Nismo (i think) front pipe $250 (2.5 into 3 inch)
Jap cat back twin exhaust for GTR / gtst? $800 3 inch out of cat, then 2.75 twins through to 2x 98mm tips. Supported 400rwkws - only for sale because I have upgraded to full titanium. (Exhaust pic on car at track)
RB26 valve springs $50
R34 RB26 std cams + gears $200
R32 GTR AFMs x2 good condition $200 - removed due to upgrade to PWR FC d-jetro
Misc
Alloy surge tank $50
Kenwood tape deck / 12 disc stacker with remote $50
Greddy turbo timer $30
Custom sub box for R32 GTR/gtst with strut brace (2x12inch subs) $100
Pioneer TV tuner box to add TV to your DVD screen headunit $300 including aerials and remote
'Its all gotta go' - help me purge my garage of things I don't need. Pickup is preferred (Adelaide western suburbs) however could ship at buyers expense. First in with the $$ gets the parts!
Cheers
Andrew
Blue32
https://www.sau.com.au/forums/topic/236304-various-parts-for-sale/
Add Mines Chipped computer for R32 GTR - $350
Tomei Sump baffle - excellent condition used only 2000kms $200
ARP Rod bolts RB26 $100
Standard battery 6 months old new $130, sell $80
Also 5 x RB26 rods with ARP rod bolts, perfect condition $150 or offer (it becomes obvious why there isn't 6 in the pic......)
Tomei sump baffle now $180ono
RB26 standard oil pump $100 ono (upgraded to Tomei......aww crap, more $$$$)
RB26 R32 GTR harmonic balancer $50 good condition
Added oil air catch can - fits in front of battery and is located via battery bracket bolt on radiator support panel. see pic $150
I have updated to a rather spanky dual catch can setup for oil control on the track.
STD 05U turbos x 2 good condition (replaced with 517z's) $400 pair ONO SOLD pending payment Thanks Marky
RB26 R32 GTR harmonic balancer $50 good condition SOLD pending payment Thanks toy86
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
