G'day all at skylines australia.
Hi im new to the forum and the import car scene so i apologise for any silly questions in advance, after many years of tossing up "should I, shouldn't I, that will hurt the budget," I finally bit the bullet and bought a 1993 R32 gtst. I love the car, looks good, sounds great and goes really well (so my last car was a nissan micra 55kw, hardcore!) and thankfully I managed to find a good condition 32. But unfortunately it needs some replacement parts (only lil things), and as all of you probably already know autobarn, repco and supercheap are only any good for performance upgrades (if you like cheap no name parts). So my question is if I am looking for standard replacement auto parts for skylines, where in the northern side of Brisbane do i need to look? who can i find who sells them?
https://www.sau.com.au/forums/topic/236343-hi-chasing-parts-please-help/
howdy mate, good to hear that you jumped a good 100kw
i have found that if you are looking for parts checking out the traders on the forum (the actual shops) is a great place to start, then post in the wanted forum and see if anyone has the part, often people buy parts for thier rides and never get to putting them on so just wanna sell them, which means cheap good new/near new parts for you. also there is the private sales area have search there for parts,
youll find that the SAU community is very friendly and its oftern cheaper to get from them, win win they say,
all the best, hopw you enjoy the 32
alex
alex
Thanks for your help INVRTD, ill check out some of the traders and see how i go
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
