I have RE001's on my GTS-R, 280rwkw RWD - you can read my post on page 1 for more details.
One of the best tyre for the dollar in the wet that's ever been on it. I've never done burnouts on them etc. I've found in the past doing burnouts on street tyres can make them go "off" and be uttery useless.
If you don't have traction I'd look @ other things like suspenion, diff etc.
Not the Adrenalins dude, the Playz. Or are they the same thing?
  • Replies 47
Playz are JDM but are also a very good tyre. They are a performance tyre indeed and have very similar tread to the adrenalin
Bridgestone ADRENALIN RE001_____________________Bridgestone PLAYZ PZ-1
My Adrenalins have been on the front of my car for over 30,000kms now and still have tread left but are going to need replacing soon. They are a littel vague in the wet now but so are the newer kuhmo's on the rear. I don't know what will get next. Prob go back tothe trusted Eagle GSD3
RE002 wll need to be a tremendous tyre, because the RE001 is in transition over to RE002 as we speak.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
