Read the post by rips a few up. I wouldn't worry at all about using rb25 head studs.
Yeah i seen that , 8 second defs made me feel better but usually 8 seconds could be rebuilt motors after so many runs etc..
Ok this is excellent feed back... This makes me feel alot better about it.
Did you guys torque the bolts to the recommended setting or go a lil extra?
From memory it was like 85
Dont go more torque than in the manual.
Any more may distort the deck of the block which you dont want.
Also remember the RB30 block is thinner and weaker around the bolt holes, the block material is also a lot softer than studs, so removing thread to fit a bigger stud only weakens your blocks deck area for the sake of adding more bolt strength which is already more than adequate.
The deck will distort more than the bolts can stretch.
We are using RB25 studs on our 600KW build.....any give will be from the block deck distorting to hold the studs/head down, not weak studs stretching......
Go back to page 1, 2 well known builders who do this for a reason, if there was a gain going bigger, they would have been doing it.
Edited by GTRPSI
This is what was tripping me out abit too, no tuner i spoke to said they have ever encountered the casting mark where the idler goes... they said they are all flat .
The casting gets in the way of mine... it wasnt a big issue we made it flat but dno if that helps u guys distinguish what type of block it is.
there is at least one thread on here with a block with the same issue, I think he was in the usa, cos if you are in oz the obvious thing to do would have been get another block.
There are some posts (i think they may have been here) on the web where people have built washer type spacers of fabricated some steel to compensate for the block finish as in the pics above and it worked just fine.
sall good we were able to make it flat and fabricate a solid spacer for it . :)
that's the proper way to do it.
as alrady said, you can get a washer style pacer made, but being timing belt, youd want to be 100% perpendicular.
Couldn't you get sleeves made up to slip into the head bolt holes so you can just use rb25 ones?
You don't need sleeves. It's the dowels that align the head to the block, not the bolts or studs.
  • 4 weeks later...
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
