hrd-hr30 Posted October 21, 2008 Author Share Posted October 21, 2008 Well they say Lakeside is the highest average speed of any track in Australia. But I know the locals say the same thing about PI... so to compare i just went and found the outright IPRA lap records for both tracks (IPRA was just the easiest for me to find this data): Lakeside (2.41km) Wayne Wakefield Mazda RX3 25/10/1998 0:57.4500 Phillip Is (4.448km) ROHAN AMBROSE MAZDA RX7 12/09/1999 1.46.0362 Unbelievably, both lap records work out to be 151.01kph average speed - equal to 2 decimal places! The Supra is basically the way I bought it from Japan. Its got Jap Teins, Jasma exhaust and pod filter. It has the small brakes but they do a pretty good job - don't fade or go long in 5 or 6 laps of Lakeside. No other suspension mods apart from the Teins, but I spent a fair bit of time messing around with ride heights to find a nice balance. And we got as much camber and castor out of the standard adjustment facilities as possible. Camber maxed out at 2 degrees on the right, but we got 2.5 on the left. Castor is 3.5 degrees. Zero toe. I haven't messed with the rear end alignment yet. Tyres are Kumho Ecsta XS (KU36) 245/40 & 275/35R18. They're not a real semi slick with a treadwear rating of 180, more of an in-between tyre like the Toyo R1-R but they have a treadwear of 140. Engine is standard boost, standard intercooler. I did what they call the 'TTC mod' which involves re-routing a couple of boost lines that control the operation of the vavle to the second turbo to make it run in parellel rather than sequential. Gives you a fair bit more mid-range, but obviously nothing extra up top. It was hopeless on the track in sequential! It really needs to be driven hard to get those times though. There isn't anything left in it - not with me at the wheel anyway. And I have alot of experience at Lakeside, which is a massive advantage there. I'm a bit surprised to only be 4 seconds off the IPRA lap record in a near standard road car in full street trim and street tyres! Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4209571 Share on other sites More sharing options...
260DET Posted October 21, 2008 Share Posted October 21, 2008 I can't vouch for the accuraccy of the tacho in an 18 year old car, but it's definately moving. Consider I'm entering the straight at a fair clip in fourth gear and pulling fifth about 30 yards before the tower, seems pretty accurate to me? Lakeside is quick you know Was yours the black R32/33? in Harry's group? Some quickies in that group, black RX7 of course, black Silvia, white Silouette. Good to watch you blokes in action Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4210025 Share on other sites More sharing options...
Marlin Posted October 21, 2008 Share Posted October 21, 2008 Hey Richard, yep thats my 32 in Harry's group. Are you running one of the Z cars out there? Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4210682 Share on other sites More sharing options...
Roy Posted October 22, 2008 Share Posted October 22, 2008 I knew Lakeside is quick and the entry on to the straight is quick...lol from watchin Touring car races Just surprised as my car is only a tad quicker down the straight at PI and its all down hill, copme onto the straight similarily in top of 4th into 5th so at about 180km/h...and i have substantially more power?!?! So it seems that my extra grunt is only good for another 5-10km/h Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4210893 Share on other sites More sharing options...
hrd-hr30 Posted October 22, 2008 Author Share Posted October 22, 2008 the turn onto the straight at Lakeside isn't that fast. about 140kph I'd say. I don't think Ben has that much speed on me down the straight either - I'm hitting 214 by the braking area after the kink, and seem to pull away in a straight line. Maybe its got a lower diff ratio? Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4211122 Share on other sites More sharing options...
Marlin Posted October 22, 2008 Share Posted October 22, 2008 Hmm yeh, I dunno whats going on? Thats the only thing that could explain it I guess...... Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4211275 Share on other sites More sharing options...
Roy Posted October 22, 2008 Share Posted October 22, 2008 Gearing could be different. But mine is pretty damn short anyway. Just keep an eye on if you were run 4th gear to 7,000rpm what speed it equates to? The gearing of the GTSt (tyre diam permitting) is that if you have the std ECU then you hit the speed limit and the rev limit in 4th gear pretty damn close together. So top of 4th gear is typically around 180km/h at 7,500rpm. LOL, i use every one of those revs as the turbo needs it You can see the gearing is pretty short as i am almost running out of revs in 5th gear and i am only about 235km/h http://au.youtube.com/watch?v=y2az4jeRzvg Oh and Ben, this was my car with the Bilsteins pre Teins. It has settled down a lot with regards to pitching under brakes and lift off oversteer, all the nasty stuff Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4211550 Share on other sites More sharing options...
Marlin Posted October 22, 2008 Share Posted October 22, 2008 Roy, you need a decent seat dude, look at that move around! lol I can't wait to get down to PI, apparently there's a two dayer there run by Stokel next month that sounds like fun, I won't make it though Your car sounds awesome, I don't rev past seven as it just runs out of puff with the std turbo. As I said can't wait to get your Teins in it, I reckon it'll be a vast improvement Love to tell you more about speeds, but the speedo dunt work :[ Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4211831 Share on other sites More sharing options...
Roy Posted October 22, 2008 Share Posted October 22, 2008 Roy, you need a decent seat dude, look at that move around! lol I can't wait to get down to PI, apparently there's a two dayer there run by Stokel next month that sounds like fun, I won't make it though Your car sounds awesome, I don't rev past seven as it just runs out of puff with the std turbo. As I said can't wait to get your Teins in it, I reckon it'll be a vast improvement Love to tell you more about speeds, but the speedo dunt work :[ Yeh, i have a seat but i dont leave it in when i am doing lots of street driving. Before PI it was a rush to get tune leaned on for more power and new tyres fitted, so seat was left in the bedroom...i miss it when its not in the car. Yeh, since i am not tracking my car at present i welcome the R32 brotherhood borrow some parts to help us all suss out what works and where we can improve our respective steeds Bumpy Lakeside will be a real test for them and you are a more experienced driver then me so any thoughts would probably be more accurate then mine. LOL, but i would love to see an in car vid to see how the car is handlling/driving with them Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4212795 Share on other sites More sharing options...
hrd-hr30 Posted October 22, 2008 Author Share Posted October 22, 2008 I think my speed calculations might be a bit optimistic too. I found my copy of July Motor magazine yesterday with a PCOTY test at Lakeside. The Porsche GT2 hit a top of 215kph and ran 58.5 according to the performance box data. They come with Michelin semi slicks and it was driven by Warren Luff I think. The Supra can't be doing the same speed as that Porsche. That's what you get for using speed per 1000rpm data from the internet I suppose... Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4212955 Share on other sites More sharing options...
hrd-hr30 Posted October 23, 2008 Author Share Posted October 23, 2008 marsta photography has his pics up: http://marsta.com/gallery/2008/081019_LSR/ shots of both Ben and I on that title page hitting apexes Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4213335 Share on other sites More sharing options...
Marlin Posted October 23, 2008 Share Posted October 23, 2008 Sweeeet One shot each though!!!! geez Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4213436 Share on other sites More sharing options...
hrd-hr30 Posted October 23, 2008 Author Share Posted October 23, 2008 (edited) I found about a dozen of mine from last weekend in the gallery linked off that page. like this one Edited October 23, 2008 by hrd-hr30 Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4213627 Share on other sites More sharing options...
Marlin Posted October 23, 2008 Share Posted October 23, 2008 lol... trying much? Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4213669 Share on other sites More sharing options...
Marlin Posted October 23, 2008 Share Posted October 23, 2008 I'm actually jealous Harry that you can use the ripple strips. If I so much as touch any of them with mine (with the exception of the last corner) it just spits itself into the scenery and most likely catches on fire lol Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4213717 Share on other sites More sharing options...
260DET Posted October 23, 2008 Share Posted October 23, 2008 Hey Richard, yep thats my 32 in Harry's group. Are you running one of the Z cars out there? Yeh the slowly driven dark blue 280ZX coupe Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4214100 Share on other sites More sharing options...
danny m Posted November 11, 2008 Share Posted November 11, 2008 way to go Danny Mischok! a driver with at least 10 years experience in IPRA circuit racing even manages to look like a total fkwit in a field of noobs in their road cars! good work mate!looks like I'll be back in the Supra instead of the Datto this weekend... HI Harry It's amazing what you find when you google your name! You whould probably get your facts straight before shooting your mouth off as the crap that went on with that knob Doug Chappel was from his own inexperience as most of us that actually race and not potter around at sprints always give it a bit of a suirt coming out of the pits IN THE RAIN to see how much tractions available and unlike most my thing comes on like a train at 4000rpm and like bounce off the limiter at 10k in the dry let alone the wet but Doug or John wouldn't know that as they've never had anything with any poke! Then when he carried on like a spoilt 5 year old because I didn't see the black flag, is because it was raining and mine like every other IP car doesn't have a heater so the car was fogging in places and when go down the straight with the Motec saying hte front wheels are doing 178kph and the back wheels doing 204kph with a G sensor reading strange, you know maybe I wasn't going in a dead straight line and I was a little busy! as even when we raced there for real they had two black flags, 1 at the start line up at the tower and another coming out of the carousel as you never saw the one on the start line let alone one being held by an inexperienced knob on the fence! As far as the noise of the thing it has been tested numerous times here in Qld and interstate by the NSW EPA! at has never read more than 92.6db at 30mt's as per Aust Standard and even here at Mt Cotton on their on and the Redlands Shire Councils regularly calibrated computerised monitoring gear the car never goes past 92db with it normally around 91.6db. So to find out that I was being judged on a rather suspect hand held piece of junk what hasn't ever been properly calibrated and the controllers not being able to decide between themselves whether it was 102.5 or 106.5db does not distress me that much but what does worry me is the amount of bullshit going between all parties that control Lakeside is that you guys better make the most of the opportunity you have now as it could all go pear shaped as the council had unrealistic goals when even brand new road cars are failing the noise limits with ADR complianced exhausts. And yes I am welcome back with the car but they want me to rework the exhaust but they will not accept that it isn't the exhaust which is popping their Dick Smith-Tandy Radio Shack sound meters but instead the induction noise If you have any questions or disagreements with anything I've said ring me as I don't bite and I tend not to shoot my mouth off too much in public Danny Ps If your under the impression that you were going to beat me around there I'd get you credit card out as my old single cam engine did 60.8's on old Yokohama A008R tyre and not even the RS's! and Gerry got down to 58.29 sec with his 168RWHP YB Cosworth powered Escort and mine makes ALOT more than that and has had a lot more development and before you start going on about the track IT WAS ALWAYS THAT BUMPY and the patches on the corners they aere always there in some form so you can't blame that for you only doing high 2's Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4255603 Share on other sites More sharing options...
hrd-hr30 Posted November 14, 2008 Author Share Posted November 14, 2008 (edited) well I did beat you out there, by about 11 or 12 seconds that day!!! So if you're under the impression you're going to beat me out there, you better sharpen up a bit mate! And unlike you, I only got 1 clear lap after I passed the STi that was holding me up., hadn't driven the Datsun since the AHC in 2007, and had never driven it in the wet. So much for you not pottering around at Sprints eh? high 2s? my standard Supra road car ran 1:01.3 last time on street tyres (not semi slicks) on the track as it is in 2008. Not realy worth comparing to what you (or whoever Gerry is) claim to have done over 7 years ago. We all saw what you were capable of the other week - 1:20-odd! Your car was easily the loudest car there on the day, and was never going to be under the required db limit. It doesn't matter whether the noise is coming from the exhaust or the induction, there's a noise limit and your car was way in excess of it. And you ignored black flags lap after lap. They were hanging out way over the pit wall with a giant black flag... its you responsibility to look out for flags at the flag points. I managed to see all the flags just fine and I don't have any demisting or even working wipers in the Datsun! My Supra only has a cat and a Jasma cannon on the back and it easily passes the noise tests out there. My Datsun only have a res and straight through muffler and again easily passes. So I call bullsh1t on the brand new road cars failing the noise tests at Lakeside. don't it make ya proud? http://www.queenslandraceway.com.au/lakesi...rral_111008.pdf Edited November 14, 2008 by hrd-hr30 Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4260623 Share on other sites More sharing options...
G_T_R Posted November 14, 2008 Share Posted November 14, 2008 Still making new friends i see Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4261382 Share on other sites More sharing options...
hrd-hr30 Posted November 14, 2008 Author Share Posted November 14, 2008 (edited) Still making new friends i see yeah, much like you with this comment. I've known Danny for years Vince, whoever you are... what's your problem anyway? Never met you or had any dealings with you. All I can remember is you taking exception to me posting to let other SAU people know about the Lakeside Sprint Series when it started, and you felt you had to rush to Paul's defence for some reason just because he also ran 1 day out there??? That ain't me making new friends, that's all you bud. http://www.skylinesaustralia.com/forums/La...97#entry3933297 Edited November 14, 2008 by hrd-hr30 Link to comment https://www.sau.com.au/forums/topic/236438-lakeside-sprints/page/4/#findComment-4261894 Share on other sites More sharing options...
