Make: Nissan
Model: R32 GTR
Milage: 116000
Transmission: GTR Box with OS Giken gearset
Colour: Grey
Complied? Yes
RWC supplied? No
Currently registered? Yes
Price: $43000
Contact: <removed>
Comments / Modifications: Very fast street car making big power on pump fuel. The car makes 400 kw on wastegate pressure and over 450 on high boost setting (454.9 kw with 98 RON). I've got multiple dyno sheets for any prospective buyers or they can check them out on the computer down at Advan while conducting an inspection. The high trap at WSID of 133 mph was done in full street trim with complete interior with half a tank of pump fuel. The car has currently run a best ET of 11.0 @ 132.87 mph at WSID without being aggressive on it with the R34 GTR wheels and street rubber. Hook up the MT's and you'll run well into the 10s on your first pass out at WSID without doubt! It has GREAT top end power as you can see from the videos.
All work carried out by Peter Hopkins at Advan. I'm more than happy to have prospective buyers check out the car on the workshop hoist so they can have a good look over it and see how great condition its in. The car is for sale as I'm keen on doing another build or picking up an R34 GTR. I've all receipts for the car since it's been imported from Japan and from the work I have had carried out with the engine build. Engine was rebuilt 10,000 km ago and has great drivability around town
Obviously you can tell from checking out the modifications list that no expense has been spared to build a big power and reliable RB26, this car has never missed a beat and has neck snapping performance. This car is FULLY ENGINEERED with papers detailing all the modifications. The replacement value of the engine alone is worth more than the asking price. Save yourself some money and buy this one!
Pictures of engine build and car to follow at the bottom
There's a
The current best ET at WSID here
ENGINE
Arias forged pistons
Trust T78 turbo kit
Complete Trust exhaust from Turbo back
1000cc Sard injectors
Z32 AFM’s
Cold air box enclosure
Trust pods
Sard fuel pressure reg
Sard fuel rail
N1 water pump
JUN oil pump
Apexi PFC
R34 crankshaft
R33 GTR head
Ported head
OS Giken cam gears
Tomei procam 280-272 11.50 lift
Tomei Type C valve springs
Tomei valve lifters
Tomei cam cap studs
Tomei valve retainers
Oversized valves
Bronzed valve guides
Nissan engine gasket kit
Trust 1.8mm head gasket
Nismo 62 degree thermostat
Advan sump extension “Group A race” (Performance Metalcraft)
ARP head stud kit
ARP main stud kit
Trust intercooler and pipe kit
Trust BOV
Earl’s oil cooler kit
Nismo conrod and main bearing kit
Eagle rods and rod bolts
ACL race bearings
New timing belt
Block/head modified for engine rebuild
Earl’s braided lines
Dual pump surge tank
2 x 044 Bosch fuel pumps in surge tank with in tank lifter
Spitfire coils
new spark plugs
All new hoses and belts
DRIVETRAIN
Exedy triple plate clutch kit
4.38 diffs
OS Giken gearset
SUSPENSION
OHLIHNS Coilovers
CUSCO front strut brace
NISMO rear lower arms
NISMO rear upper arms
NISMO aluminium Cradle bushes
Whiteline Swaybars, Front blade adjustable
WHEELS
R34 GTR Rims
R32 GTR rims wrapped in MT ET drag radials
EXTERIOR
Nismo bonnet lip spoiler
NISMO boot lip spoiler
Nismo N1 bar inserts
NISMO sideskirts
ELECTRICS
BLITZ Dual S-BC
PIVOT turbo timer
HKS 52mm Boost Gauge
6 point Immboiliser alarm
BRAKES
R33 GTR Brembo's with Pagid pads and Dba 4000 discs
R32 GTR
setupMaltech braided brake lines
Ferodo DS2500 brake pads (front)
Race Brakes Comp2 brake pads (rear)
ENDLESS Brake master cylinder stopper
Motul RBF600 fluid
INTERIOR
MINES 320km/h Speedo
Nismo short shifter
NARDI Leather gear knob
MOMO Competition steering wheel
Greddy 522 Pillar gauge mount
Quell fire extinguisher (cams approved)
5-piece GT-R floor mats
Stereo
Pioneer DEPH-4650 CD player
Alpine MRP-240 Amp
Alpine Type-R splits (front)
Pioneer 6.5" speakers (rear)
Boss Audio Amp Kit
Pictures
Look stock
Sump extension for larger oil capacity.
  • 1 month later...
WOW what a nice car with well thought out mods good luck with the sale.If this was still
around in 6 months time I would be very keen
Hehe thanks!
Back up for sale, buyer backed out at the 11th hour.
New Brembo's fitted now fitted and work great.
Available for viewing at Advan Performance by appointment with Peter Hopkins or myself.
Regards
Ben
  • 4 weeks later...
Car is back at Advan available for viewing by appointment.
Good value as the dollar has declined quite dramatically against the Yen. It'd cost a lot more to build a tough RB now days than it would 12 months ago.
  • 2 months later...
    • Which are almost all nonsense. Ignore. Obviously enough, if it is not a porous block, then any such thing is a waste of time. External block surface? Would be a waste of time, if the block was actually porous. It would need to go on the inside, which is inaccessible, and even if the block was open deck so that that area was acessible, it would be unlikely to work. But seeing as this is all nonsense, stop worrying about it.   If the coolant is coming from the side of the block it is 10:1 odds that it is either a welch plug, or it is coming from the head gasket. Maybe from one of the coolant lines feeding the turbo, or even the heater. Liquids that leak from up high can travel sideways along casting surfaces or pipes, etc on the engine before finding a spot from which to drop.
    • Yeah rust is sadly also a bit of an issue on my car. Doubt there is many cars out there that actually have no rust in those aeas. The strut towers look fine but some of the surounding metal sheets show a bit of brown cancer peeking out from in between. I hope I can make do with external remedies and won't have to rip open the whole front end anytime soon. It looks somewhat minor compared to some shit I have seen online. I have worked on a few cars but I expect the RB26 to be my first 'engine out' job at some point.
    • Welcome Jan, It's very likely that you are in over your head. You'll just have to learn to swim hard and fast! These old rust buckets have more ways to bankrupt us than almost any other car. But hopefully there's nothing wrong that ruins the whole show! We can help a fair bit. There's plenty here who've been fixing these things for >25 years. cheers
    • Hi all. First off, thanks for reading my post. So end of last season I put the car away knowing I was leaking at least two fluids. One of them being rear turbo's oil. I went to my car recently that is waiting in a garage to take a peek with my boroscope to try and see if I can narrow down the souce of oil before taking it out of storage. What I found is not so great I think. The rear turbo is (probably) leaking from the oil drain. The hose and it's clamps are probably the original ones, so most likely just worn out or loose. However I spotted a line of rust going straight down from the turbo oil feed, as if water leaked out of there at some point. Also explains the red liquid that was dripping from my front subframe, which I initially thought was power steering. I can even see coolant drops hanging off the side of the oil pan as well. After a quick hit on the web I found a select few discussions about porous engine blocks. My question is if the pics of the turbo oil feed and the left hand side of the block (imgur link below) looks like it could be exactly that to you. Maybe someone in the community has seen it before and knows what it looks like. If it actually is a porously leaking block, has anyone attempted at fixing it with simple methods like putting a sealer in the cooling system and using something like jb weld on the block surface, or will it just leak in 2 weeks again? I could not find any detailed info or pictures on this topic. If I need a new engine, tell me softly. https://imgur.com/a/knVvmZ8
    • Hey all. I'm 23 and from Germany, September last year I bought a mildly modded 1995 GTR Vspec. Looks great and was fun so far, but I already have a list of issues of various severity that I need to take care of, potentially growing longer the closer I look. I just hope I'm not in over my head, I really want to keep the car and work towards it becoming great. I hope y'all will help me out in getting there, I am positive I will need help sooner rather than later to figure out how to proceed. greetings, some pics of the car I posted to imgur. https://imgur.com/a/StKkabz
