It wont be that easy :thumbsup:
what makes you say that?
as long as you have fuel setup sorted and you have appropriate boost control there shouldnt b too much dramas
ppl say you get 15-20% increase in power from e85
so a 330kw GTR should crack 375kw on e85... theoritically atleast
What makes Paul say that is no doubt that he makes 400kw, and knows that theory can be a long way from reality.
By all means try your theory, go get some ID2000's, a large fuel pump or two 044's, whatever EBC you like, -9's and see how you go at 24psi. Let us know how you go
Generally it seems to only be around 20-30rwkw though in terms of gains. I think 350-360rwkw would be more realistic.
What would be more interesting though... How much earlier would they come on?
Given everyone seems to gain a few hundred RPM response. Getting -9s on even sooner would really be quite something.
Whilst 200-300rpm might not sound like a lot, if its coming up in/out of throttle faster too... It would be awesome!
Yeh I'm gonna.. as soon as caltex get some elfex around my area
Would b interesting with -9s
ID1000s won't b enough?
I suppose it depends on who tunes it.
Im running ID 2000's (2225cc) and at 400rwkw im using a Duty cycle of about 63% IIRC (AFR's are about 11.6:1 Petrol corrected according to my wideband (Roughly .80 Lambda)). If you calculate that back thats just on 1400 CC worth of injector. Thats on a 2.8 with GT RS's at 1.75 bar. Its a little low as my exhuast was choking it like a whore.
That's what you do notice. That half to full throttle instant response. Well I use 'instant' very loosly with GT RS's. It was alot better with E85! pinch.gif
What area are you in? Its at a few places now, so if the skyline isn't your daily driver you'll be fine.
You're talking a 2.6L right? Mine maxed 1000's at 403rwkw but its an rb30 - capacity makes a difference.
Yeah this is an interesting point.
My throttle response hasn't got any better or worse since before and after the E85 swap. I took the time to make sure it was how I wanted it while it was on pump though.
Edit; I dont mean turbo lag.
I see that stated a lot but can't understand why! Can you explain why would engine capacity makes a difference?
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
