Hard pipe kits have been known to cause issues with compressor surge.
Same as changing stock BOV’s
In short – leave them both alone.
Seen plenty of cars make 400rwkw+ with stock piping. It's not required, nor should it be changed.
How do you guys get around the constant issue of blowing off hoses or the hoses splitting?
Seems to be a never ending process for me to constantly put hoses on with even the nut and bolt style band clamps.
And the other day I had the hose coming off the pipe on the on the right hand side running down past the air box towards the intercooler split!!
What does everyone use? Any brands better/worse?
they are not needed but I have found on track days the stock GTR stuff gets pretty soft (with heat). but plenty of people run 300kw with the stock pipes. but personally I much prefer hard pipes. I like the trust kit best. I use the trust suction kit and the trust intercooler pipe kit (need both). that replaces all the standard piping in the engine bay. they look nice. but for sure if you are on a budget it's money that is better spent elsewhere.
You can just user better clamps, that said I was using stock clamps for 20,000kms over 2 cars, and they were fine.
They were recently swapped however as it was suspected there might have been a minor boost leak.
Are you sure your engine mounts are in good order? Sounds like there is perhaps some more movement than normal going on?
Tried changing types of clamps, and even switched to the clamps I use at work (diesel fitter) which work on engines with 38psi running through them.
The engines mounts is actually something I completely overlooked. I'll have to have a bit of a look and see whats going on in that department.
Thanks for the imput Nismoid :)
or perhaps something else isn't affixed correctly and moving things around. have a good look as you really should not be having any major issues in that department
Yeah put it on a dyno if possible and have a look when it is loaded up at peak torque, should be able to see if there is much movement.
Yeah well its been on the dyno a few times in the last year and the shop that it was going to was not the best to say the least....
Anyway its going to Matty Spry down the gold coast hopefully in a couple of weeks so if i can't find it by then hopefully they might pick something up...
if by worth you mean spending 5+ hours to achieve nothing, then sure :)
you really only need to pull out the engine if your changing:
- mounts
- exhaust
- intake
- misc other stuff
all at once. otherwise, changing turbos is basically a 20bolt job, no need to pull out.
Operator10. Haven't done much yet. Finally got my car on the hoist at work. So will start on Monday night. Still haven't decided on turbos.
Engine wise check this thread I wrote it all down a while ago.
Ok was all set to have a big weekend and swap turbos and do a few other bits and pieces only to find out I can't get any -9s.
They only have -7s and -5s in stock.
Opinions on -7s? Responsive enough?
Otherwise I'm tempted to go small single eg. 3076 w/.82 rear
-7's are responsive but that depends on your definition of "responsive". On/off throttle they're great, they don't nose over at high rpm, and on an average boost setting they can give enough power to make a GTR feel like a whole new car. There's a few otherwise stock RB26's getting around the 310rwkw mark or so - area under the curve is great and you don't get caught in traffic wanting for more if that makes sense. It's also a good sized turbo setup that you can go have fun at the track or hills if that's your thing. There is probably a thread of 7's vs 9's somewhere - R31Nismoid would know of it
They have good get-up-and-go but if your idea of response is being able to pull like a freight train for 2000rpm in 3rd gear then I think you'll be disappointment (although if that's your idea of response, by a V8 :) )
Here's a -7 result;
Thanks for posting the dyno sheet N1GTR. I can see what you're saying regarding response as well. I had a chuckle at the "buy a V8" line as well. Very cheeky. Lol
With a built motor I will crank some boost into it and really see what the -7s can do.
Are the -7s bolt on in a 32 gtr?
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
