Definitive Guide To Building 300-330awkw Gt-r
-7s being a tad more responsive again (over -9) would be an excellent choice if response is your #1 goal.
FYI, here's stock vs -7 boost response (very few data points.....its rough) same engine and probably same cam timing.
I thought N1 turbos were different to -7 turbos?? The legend on your graph says N1 whereas your text says -7. I thought -7 were a lot more responsive then N1.
  • 3 weeks later...
Hey guys, great thread, some useful information in it.
i am slowly working on my car to achieve just this set up 300awkw
at the moment, i have just installed
GT2860-7 x 2 turbos
Tomei expreme dump pipes
already has a front pipe, and a hks preist cat back with a high flow 3" Catco cat. (looking at changing exhuast to one with a bit louder/better flow) any suggestions?? rear cannon style.
i have a vipec ecu (which i need to get retuned but going to wait till after mods) MAFless
it has pump incar already, so that is a non issue.
suspension is all done.
i am at the stage of buying injectors, i have been looking at seimens injectors, can anybody give me some info on which type to run if they know about seimens injectors? part numbers etc, im looking at about the 600cc mark for injectors
Also never really though about cam gears, but might also look into those b4 retune.
Cheers
Daz
ive got very similar mods to urs Daz.
im running 600cc nismo injectors with a sard intake fuel pump with a direct 14v power supply.
im also running GReddy cam gears, i think they are great on an RB26. they gave me more flexability when it came time for tuning. ie i had a choice between getting them tuned for outright power or sacrifice abit of top end for more midrange power/torque :)
Whats your max injector duty? What power is it making and what boost is that at?
+1 on cam gears
Not sure on injector duty, il have to find that out
296kw @ 19psi - cam gears adjusted for midrange, feels so responsive And just screams out of corners like a mofo :) I'm happy with it 100%
Had a good read of this thread before I started my round of mods for 300kw. My mods so far are
2860-9
Nismo 600cc
New PFC
HKS cam gears
Greddy dump/front pipe extension
Kakimoto Regu exhaust
Splitfire coil packs
Hasn't been tuned yet because of coilpack and EBC issues. But I'm hopeful I'll get close to cracking the 300 mark but at this stage I just want it tuned and running
Time and time again I see ppl try to estimate duty cycle in relation to power output but it seems like we are leaving out the most inportant fator which is afr.
A car with 600cc making 300rwkw tuned at 11.0afr will show higher duty cycle than if it was tuned to 12.0afr and making the same 300rwkw.
Can any one explain why my boost curve is fluctuating, at a glance i'd guess some sort of fuzzy logic function however im pretty sure the blitz spec r are theoretically just an open loop controller with simple duty cycle adjustment. The car is running the standard 8psi actuators on dash 7s and the blitz boost controller set to 86. When i eventually fit bigger dumps (i have stock 32), bigger afm and retune on e85, i'd like to run more boost. Is it worth while upgrading to 14psi actuators?
Cheers
Pat
No different to estimating a dyno figure range or RPM turbos will come on.
There are always variables, however you can work out 'roughly' in most cases, hence its called an estimate...
Currently running -9s with 335kw, nismo 600cc injectors and fuel pump, with a max injector duty cycle of 86%
Just for reference
What air flow meters are using to get up to that figure? Are the standard still coping or have they been changed to Nismo or Z32?
My car is getting tuned in just under two weeks with -9s and 720cc injectors so i'm thinking the AFM's are going to be the next limiting factor.
    • I did a pretty ruthless clean up before I left townsville. If it wasn't a part to suit a car I currently have it was sold or binned. I have all my stuff organised in big tubs with lids that stack from supercheap and bunnings depending on who was cheaper at the time. Parts were sorted by either chasis/motor/Fabrication/general/electrical. I have a mezzanine that's 7mx2.3m and all lives up there. Easy to access when needed and out of the way.  I also have the issue of selling and dealing with scumplace/marketbook was actually going to list stuff today but couldn't be bothered as been stuffed around too much. I generally let a few people know I want to off load stuff and people pass it on to others to contact me, generally easy sale and I'm never looking to make big dollars. Rather it gets used than go in the bin. Next clean up will be around Xmas and if doesn't go on the s15 it's going bar 2 sets of wheels.
    • Did a little bit on the V37 today. I bought this LED kit out of the US https://www.ebay.com.au/itm/125953603618. Best I could find online but didn't look great, in the end the quality was pretty much right and it did come with locations for each light including rear number plate and a few spares. The factory owners' manual was also useful with information on where to pop each light out without damage. I prefer the LED look as I use it daily including at night and the LEDs are both brighter and the white light is easier to read with. Vanity mirror comparison, LEDs just look more modern The glove box was the only difficult one (and the only one that was previously blown.....), steps were Open glovebox 50% but not fully open Push up on bottom of the box to unclip it on both side, not screws or pins to remove Remove the top stays at an angle, right side then left, because.... Before dropping the glovebox totally, remove soft close clip on left Then, remove 7 screws to release the glovebox surround Twist the globe holder anti clock to release it from the surround In this case, the LED globe supplied was wider than factory and did not fit, so I ground down each side about 1mm then inserted it Last trick, start engine to check the LED polarity is correct, the globe only operates when the engine is running (whether the box is open or closed) I also moved the 4G booster and wifi across from the Fuga, a little frustrating as I could not find a good Accessories ACC source anywhere in the boot so I'll run a wire from the cabin next time I get a chance. Also, unlike the Fuga the external antenna wire does not quite fit between the rear windscreen and the body so I think I'll have to drill a hole in the roof to mount it. Probably not that interesting for most people so I'll just post once complete
    • Pretty sure I could do but it would need to be exported and reimported as the current import approval is race only. But in practice there are plenty of other practical reasons it can't be a road car despite their potential value these days like stripped interior looms, cage to cut out etc Nah, no mods to it other than updating the roll age to current regs. It makes about 350 (laggy) kilowatts on the N1s at 18psi which is enough to push it around the place
    • This is it, folks! Our final event of the year... The big one, you all know and love - Putty Road! It goes without saying, but this is the biggest cruise in our calendar each year! A nice long drive, with a hearty pub feed at the end! Do you need much more enticing than that!?!? So make sure you wash the car, get your cameras out, block out the calendar, and get ready! We know you're all as excited as we are, so make sure you lock in the details and date below: Date: Sunday 8th December 2024 Meet Location: Corner Windsor Road and Groves Avenue McDonald's / KFC (3 Groves Avenue, Mulgrave) Meet Time: Meet at 9:00am for a 9:30am departure Destination: The Royal Hotel, Singleton (84 George St, Singleton) Map: https://tinyurl.com/saunsw-puttyrd Itinerary: We will meet at McDonald's / KFC on Windsor road and from there will head onto Putty Road. There will be a break at the Grey Gum Cafe (8679 Putty Rd, Putty) which we should reach at approximately 11:30am. For all the Newcastle folks this will be a good point to join up. From here we will continue on to Singleton for lunch. Please remember to fill up prior to heading onto Putty Road. There will not be a fuel stop until Singleton. To those running on E85, Freedom Fuel (old United) at Vineyard on Windsor Road has started selling there. At Singleton there is a range of servo's available including BP, Shell and Caltex. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back by popular demand - we're lining up another Old Pac Run! Get your cars ready for one of the best night runs on the calendar! So without any ado whatsoever, here are the details for you to save: Date: Saturday 23rd November 2024 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: Meet at 7:30pm for a 8:00pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://tinyurl.com/saunsw-oldpac Definitely an easy one for this cruise, meet at Cowan Truck Stop and jump straight onto Old Pacific Highway! Final stop at McDonald's which has plenty of parking all around. Please be mindful of the added police presence lately so best behaviour is expected! There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
