Currently running -9s with 335kw, nismo 600cc injectors and fuel pump, with a max injector duty cycle of 86%
Just for reference
Dyno graph please!
What air flow meters are using to get up to that figure? Are the standard still coping or have they been changed to Nismo or Z32?
My car is getting tuned in just under two weeks with -9s and 720cc injectors so i'm thinking the AFM's are going to be the next limiting factor.
I'm using Z32s works well recommend upgrading or like stated earlier mafless ECU
Just last weekend i make 311kw on my 32gtr. -7 turbos, tomei cams, supposed head porting, turbo back exhaust, 750cc injectors, fuel pump, pfc. I bought brand new z32 afm's, messed around getting them all fitted up nicely; when it came to getting tuned the tuner basically said we were reaching only maybe 20% of the z32's efficiency and had bigger jumps in voltage vs trim than the original so much harder to get a steady afr. Ended up swapping back to the original afm's and instantly became better to tune (smaller voltage steps meant more refinablilty) and still have 0.5v to spare. Spools up quickly and pulls harder that a professional thaiwanese girl :thumbsup:
Edited by joeyta22
For everyones information, I have compiled this spreadsheet of all the results from the RB26 dyno thread here:
SAU_dyno_comparisons.xls
This only includes results that aren't from standard turbos, but heaps of results from -7's/N1's, -9's/GT-SS, and -5's/2530.
I have also added this to the dyno thread.
And yes I did get really bored to find the time to come up with this one lol.
Hey mare do you have dyno graphs with rpm etc? If not when do you hit full boost and what boost are you running? Cheers
Just got my dyno result back from racepace. Got 316kw running 17-18psi with n1's, fuel pump, ID 1000c injectors (53% duty), nismo afm's, pfc, racepace 3.5" full custom exhaust and cam gears. This is a really safe tune. Can post up dyno sheet if you want.
Car is mega responsive and still kicks out with 285's all around 1st and 2nd gear.
Is running at 17psi max and hits that at 4500rpm, could be much better but the actuators are piss weak (only about 8psi) which is why the power becomes a little wavey around the top of the graph aswell. Overall im stoked with it tho, 200kw at 4000rpm is a great result in my eyes.
joeyta22, nice results mate. im still deciding whether to go -7s or -9s as an upgrade.
how much better are the -9s in terms of response compared to -7s?
is there any -9s dyno sheet with RPM instead of speed.
is there anyone in sydney with -7s or -9s on an unstroked motor who are willing to take me for a test drive? worth a shot asking anyway lol
Just to throw a spanner in the works for low mounts, here is a direct comparison between a -7 set up and a GT3582R on 6boost manifold :)
I dislike 35R's because they are so lazy but even a lazy single appears to kill the low mounts everywhere :nyaanyaa:
haha i got the exact same setup tuned on my car 2 days before you posted this..
Unopened rb26dett (115,000km)
tomei 260 9.15mm poncams type b
gt35 0.82 rear
6boost mani
tial 44mm w/g
700cc sards
stock rail
044 intake
tuned on BP98
485hp @ 20psi on a safe tune (at hubs)
full boost at 4300rpm, love it! shits all over my old twin setup in every way
thick line is gt35 + poncam tune, thin line is -7 tune
Apologies for the poor phone pic of my dyno graph!
Not really a spanner. It's already been established, the -7 setup was 100rwkw down @ 4500rpm compared to every other -7 set-up. That ain't no dyno variance :)
http://www.skylinesaustralia.com/forums/topic/379561-gtr-r33-v-spec-build/
So whilst a direct 'comparison', it's totally wrong to compare a working set-up with one that has major issues.
Very misleading info, although it wasn't intended that way of course.
It's not misleading at all, if you look at ANY result on the ALLSTAR dyno they are always down on midrange compared to most other dynos...
For instance my car only makes 127rwkw at 4000rpm on the Allstar dyno but 196rwkw at the same rpm on a Dyno Dynamics dyno. That was on the same tank of fuel with about 50km driving between the 2 dynos!
Another RB25 neo makes 135rwkw at 4000rpm on the Allstar dyno but 220rwkw at the same rpm on a Dyno Dynamics dyno...
Then we could compare my set up to batterys, both same motor, same fuel, same turbo, same manifold, same gate... Same top end power on the same boost on the same type on dyno. Plus same boost response and build up on the road. His makes 200rwkw at 4000rpm (funnily enough almost exactly the same as mine on a dyno dynamics) and mine makes 127rwkw...
Take from it what you will, I have no idea why it is like that but every single result I see off the Allstar dyno appears to have shit mid range compared with other dynos which explains most of the "100rwkw down @ 4500rpm"
Edited by SimonR32
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
