Definitive Guide To Building 300-330awkw Gt-r
What air flow meters are using to get up to that figure? Are the standard still coping or have they been changed to Nismo or Z32?
My car is getting tuned in just under two weeks with -9s and 720cc injectors so i'm thinking the AFM's are going to be the next limiting factor.
I'm using Z32s works well recommend upgrading or like stated earlier mafless ECU
Just last weekend i make 311kw on my 32gtr. -7 turbos, tomei cams, supposed head porting, turbo back exhaust, 750cc injectors, fuel pump, pfc. I bought brand new z32 afm's, messed around getting them all fitted up nicely; when it came to getting tuned the tuner basically said we were reaching only maybe 20% of the z32's efficiency and had bigger jumps in voltage vs trim than the original so much harder to get a steady afr. Ended up swapping back to the original afm's and instantly became better to tune (smaller voltage steps meant more refinablilty) and still have 0.5v to spare. Spools up quickly and pulls harder that a professional thaiwanese girl :thumbsup:
Edited by joeyta22
For everyones information, I have compiled this spreadsheet of all the results from the RB26 dyno thread here:
SAU_dyno_comparisons.xls
This only includes results that aren't from standard turbos, but heaps of results from -7's/N1's, -9's/GT-SS, and -5's/2530.
I have also added this to the dyno thread.
And yes I did get really bored to find the time to come up with this one lol.
Hey mare do you have dyno graphs with rpm etc? If not when do you hit full boost and what boost are you running? Cheers
Just got my dyno result back from racepace. Got 316kw running 17-18psi with n1's, fuel pump, ID 1000c injectors (53% duty), nismo afm's, pfc, racepace 3.5" full custom exhaust and cam gears. This is a really safe tune. Can post up dyno sheet if you want.
Car is mega responsive and still kicks out with 285's all around 1st and 2nd gear.
Is running at 17psi max and hits that at 4500rpm, could be much better but the actuators are piss weak (only about 8psi) which is why the power becomes a little wavey around the top of the graph aswell. Overall im stoked with it tho, 200kw at 4000rpm is a great result in my eyes.
joeyta22, nice results mate. im still deciding whether to go -7s or -9s as an upgrade.
how much better are the -9s in terms of response compared to -7s?
is there any -9s dyno sheet with RPM instead of speed.
is there anyone in sydney with -7s or -9s on an unstroked motor who are willing to take me for a test drive? worth a shot asking anyway lol
Just to throw a spanner in the works for low mounts, here is a direct comparison between a -7 set up and a GT3582R on 6boost manifold :)
I dislike 35R's because they are so lazy but even a lazy single appears to kill the low mounts everywhere :nyaanyaa:
haha i got the exact same setup tuned on my car 2 days before you posted this..
Unopened rb26dett (115,000km)
tomei 260 9.15mm poncams type b
gt35 0.82 rear
6boost mani
tial 44mm w/g
700cc sards
stock rail
044 intake
tuned on BP98
485hp @ 20psi on a safe tune (at hubs)
full boost at 4300rpm, love it! shits all over my old twin setup in every way
thick line is gt35 + poncam tune, thin line is -7 tune
Apologies for the poor phone pic of my dyno graph!
Not really a spanner. It's already been established, the -7 setup was 100rwkw down @ 4500rpm compared to every other -7 set-up. That ain't no dyno variance :)
http://www.skylinesaustralia.com/forums/topic/379561-gtr-r33-v-spec-build/
So whilst a direct 'comparison', it's totally wrong to compare a working set-up with one that has major issues.
Very misleading info, although it wasn't intended that way of course.
It's not misleading at all, if you look at ANY result on the ALLSTAR dyno they are always down on midrange compared to most other dynos...
For instance my car only makes 127rwkw at 4000rpm on the Allstar dyno but 196rwkw at the same rpm on a Dyno Dynamics dyno. That was on the same tank of fuel with about 50km driving between the 2 dynos!
Another RB25 neo makes 135rwkw at 4000rpm on the Allstar dyno but 220rwkw at the same rpm on a Dyno Dynamics dyno...
Then we could compare my set up to batterys, both same motor, same fuel, same turbo, same manifold, same gate... Same top end power on the same boost on the same type on dyno. Plus same boost response and build up on the road. His makes 200rwkw at 4000rpm (funnily enough almost exactly the same as mine on a dyno dynamics) and mine makes 127rwkw...
Take from it what you will, I have no idea why it is like that but every single result I see off the Allstar dyno appears to have shit mid range compared with other dynos which explains most of the "100rwkw down @ 4500rpm"
Edited by SimonR32
    • I did a pretty ruthless clean up before I left townsville. If it wasn't a part to suit a car I currently have it was sold or binned. I have all my stuff organised in big tubs with lids that stack from supercheap and bunnings depending on who was cheaper at the time. Parts were sorted by either chasis/motor/Fabrication/general/electrical. I have a mezzanine that's 7mx2.3m and all lives up there. Easy to access when needed and out of the way.  I also have the issue of selling and dealing with scumplace/marketbook was actually going to list stuff today but couldn't be bothered as been stuffed around too much. I generally let a few people know I want to off load stuff and people pass it on to others to contact me, generally easy sale and I'm never looking to make big dollars. Rather it gets used than go in the bin. Next clean up will be around Xmas and if doesn't go on the s15 it's going bar 2 sets of wheels.
    • Did a little bit on the V37 today. I bought this LED kit out of the US https://www.ebay.com.au/itm/125953603618. Best I could find online but didn't look great, in the end the quality was pretty much right and it did come with locations for each light including rear number plate and a few spares. The factory owners' manual was also useful with information on where to pop each light out without damage. I prefer the LED look as I use it daily including at night and the LEDs are both brighter and the white light is easier to read with. Vanity mirror comparison, LEDs just look more modern The glove box was the only difficult one (and the only one that was previously blown.....), steps were Open glovebox 50% but not fully open Push up on bottom of the box to unclip it on both side, not screws or pins to remove Remove the top stays at an angle, right side then left, because.... Before dropping the glovebox totally, remove soft close clip on left Then, remove 7 screws to release the glovebox surround Twist the globe holder anti clock to release it from the surround In this case, the LED globe supplied was wider than factory and did not fit, so I ground down each side about 1mm then inserted it Last trick, start engine to check the LED polarity is correct, the globe only operates when the engine is running (whether the box is open or closed) I also moved the 4G booster and wifi across from the Fuga, a little frustrating as I could not find a good Accessories ACC source anywhere in the boot so I'll run a wire from the cabin next time I get a chance. Also, unlike the Fuga the external antenna wire does not quite fit between the rear windscreen and the body so I think I'll have to drill a hole in the roof to mount it. Probably not that interesting for most people so I'll just post once complete
    • Pretty sure I could do but it would need to be exported and reimported as the current import approval is race only. But in practice there are plenty of other practical reasons it can't be a road car despite their potential value these days like stripped interior looms, cage to cut out etc Nah, no mods to it other than updating the roll age to current regs. It makes about 350 (laggy) kilowatts on the N1s at 18psi which is enough to push it around the place
    • This is it, folks! Our final event of the year... The big one, you all know and love - Putty Road! It goes without saying, but this is the biggest cruise in our calendar each year! A nice long drive, with a hearty pub feed at the end! Do you need much more enticing than that!?!? So make sure you wash the car, get your cameras out, block out the calendar, and get ready! We know you're all as excited as we are, so make sure you lock in the details and date below: Date: Sunday 8th December 2024 Meet Location: Corner Windsor Road and Groves Avenue McDonald's / KFC (3 Groves Avenue, Mulgrave) Meet Time: Meet at 9:00am for a 9:30am departure Destination: The Royal Hotel, Singleton (84 George St, Singleton) Map: https://tinyurl.com/saunsw-puttyrd Itinerary: We will meet at McDonald's / KFC on Windsor road and from there will head onto Putty Road. There will be a break at the Grey Gum Cafe (8679 Putty Rd, Putty) which we should reach at approximately 11:30am. For all the Newcastle folks this will be a good point to join up. From here we will continue on to Singleton for lunch. Please remember to fill up prior to heading onto Putty Road. There will not be a fuel stop until Singleton. To those running on E85, Freedom Fuel (old United) at Vineyard on Windsor Road has started selling there. At Singleton there is a range of servo's available including BP, Shell and Caltex. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back by popular demand - we're lining up another Old Pac Run! Get your cars ready for one of the best night runs on the calendar! So without any ado whatsoever, here are the details for you to save: Date: Saturday 23rd November 2024 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: Meet at 7:30pm for a 8:00pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://tinyurl.com/saunsw-oldpac Definitely an easy one for this cruise, meet at Cowan Truck Stop and jump straight onto Old Pacific Highway! Final stop at McDonald's which has plenty of parking all around. Please be mindful of the added police presence lately so best behaviour is expected! There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
