hey guys, basically ive rebuild my engine bottom end similar to (piranha) , with tomei cams and gears, and im using -5s. Using the standard fuel pump, my car is about 320awkw. Im using 750cc injectors with standard rail. Sorry for this stupid questions, but :
1. With the aftermarket injectors,do u reckon i should change my stock rails?
2. Is it advisable to change to 1000cc injectors for better performance?
What else i can do to increase my power? Thank you.
p.s: this is subjective, but which is better, open pod or the stock box?i was told better to use stock box(cooler air)
cheers.
Change fuel pump to nismo or similar.
Stock rail is fine
How much power do you want will determine injector size.
Personally I would
Stick with stock airbox
How much boost you running??
Put 20+psi through them and you could get close to 380awkw with those turbos
cheers.
I have so far made 420 rwkw with a standard R33 Series 3 airbox. There is nothing wrong with them.
keep the std airbox
nothing wrong with them at all.
keep the standard rail, i am using the std rail with 1000cc injectors and it works fine
i'd stick with what you've got, the only thing i would change is the fuel pump.
a bosch 040, 044 or walbro or jap (tomei, nismo) will be fine.
if you can run over 20psi, do it to really wake up the -5's
Thought id give a quick update.
I put a pair of -7s on and i love them. They just feel so good after having early nismos (especially ones that were rooted lol)
Pulled 261rwkw at 1 bar so pretty happy with that for the moment. That was with std injectors/pump/afms so next step is to upgrade those and shoot for 330rwkw.
(although i have started collecting bits for a dirty thirty conversion so may just have wait for that lol)
Cheers
Luke
Ok so I have gtss turbos, nismo pump, injectors, apexi pods or airbox with nismo filter (depending what I feel like at the time lol). Currently running a power fc d-jetro but changing to haltech platinum pro inthe next few months.
I'm looking into cams. I'm getting cam gears, doing the water pump, timing belt etc all at the same time so why not do cams lol.
I'm a bit confused on what to get.
The tomei type b 260 in/ex with 9.15 lift or
Hks 264 in/ex with 8.7 lift (other hks cams with same lift are 256 or 272).
Appreciate your input into cam selection for my set up. Please don't post dont worry about cams or there not needed lol.
My mate put his pod via a silicon joiner through the stock IC hole into where the wheel arch stock front mount is located. The difference is night and day, but what about water/mud in winter etc, do you guys see any issue in mounting it here? It seems like such a an easy and effective modification.
Edit: stock place in a GTS-T, so I guess you guys would need to make another hole, but regardless thoughts?
Edited by Rolls
I'd go the tomei's, only because they have more lift and they give more torque from that compared to the HKS cams. Have driven R's with both..
Each to their own ;)
A question for the more knowledgable.
Wanting to know with a built RB26, supporting mods with -7's optimal RPM and boost setting PSI please.
Tomie Type A poncams 260 9.15
Chasing 300 or so awkws
Let me know if you need more build details
I would gone different dumps, but for 300/320awkw it's not going to make much of a difference.
24psi peak, 8000rpm will be fine. Set the limiter for 8200 or so and fit a shift light to go off at 7500rpm.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
