Definitive Guide To Building 300-330awkw Gt-r
Appoligies for not expanding. Required a fair amount of Dyno time and eventually a new firmware upgrade from Haltech onto the Sports 2000.
I'll get a better explanation but apparently now my boost increases with my foot going down on the accelerator (Synced to RPM ???). So if it's halfway I'm running about 10-12psi and when its all the way down I run the current 18psi. Dont ask me how I'm not in the know but I will get a better explanation from my Tuner with some key Tuner speak that will explain.
Plus it's going all the way to 8250rpm where it's configured to cut out.
Little off topic, but part of my 300-320rwkw goal, is just to replace the Front pipes, I'm deciding between these 2.
http://www.ebay.com.au/itm/HKS-MILD-STEEL-FRONT-PIPE-NISSAN-SKYLINE-R32-GTR-/140681646997?pt=AU_Car_Parts_Accessories&hash=item20c1479395
http://www.ebay.com.au/itm/380339215174?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
The HKS one doesn't say anything about a direct replacment though. But it looks like it will bolt straight on, and half the price :). will I really see any noticeable gain in power or flow? Do people replace the front pipes when there going for this 300-330 goal.
Cheers
Also try the Trust/Greddy MX front pipes, they are listed at $608 on the GCG website (might even get them cheaper if you speak to Mark out there) and they are the same sIze as Apexi. I use them and they made a big difference to midrange even with the old standard turbos, so definitely go the bigger pipes.
If you are chasing 300+ then they need to be swapped out otherwise you will have a rather large exhaust restriction.
Damn, now I gotta decide between Greddy & Apexi. On another note, could I change the stock dump pipes at the sametime? Like a swap in and out, or does this requite other stuff removed, turbo's out etc :blink:
Edited by 91BNR32
Wouldn't even bother with dump pipes unless you are pulling the turbos out, a quick look under there will tell the story. The std turbos will run out of puff before the dumps.
Just stick with big front pipes and big hi flow cat until the turbos are swapped out, then change the dumps.
Thanks. it says it suits BNR32, so hopefully will bolt straight on. Has to be an improvement over the Stock front pipes :)
Is the exhaust std on the car??
Basically fit the biggest exhaust you can to free as much flow as possible
Lucky I had a look under the car, it has some sort of custom front pipe with a built in decat pipe on it aswell. Weird.. pinch.gif looks like 2 x 65mm & 80mm out. I'd need to buy a front pipe & a high flow cat if I were to do a direct replacement. But yea better flow = better power.
Would it make sense to buy some Nismo AFM's to have a comfortable 300-320 rwkw? I know the Standard ones max out at about 300, is this safe though?
no point buying AFMs or injectors for your goals. We've said it a few times already.
Both are fine for upto 300rwkw, you can make more, it just depends. Every set-up is different.
If it maxes out @ 290rwkw, so be it. For the $1400 it'll cost (AFM/Injectors) just to get 10-20rwkw...
Only you can decide if it's of any value to you. I'd say no.
Also buying 2nd hand AFMs is also wasted money. If they start to fail or play up, you end up buying new ones or chasing gremlins.
Im still tossing up what setup to go for.
As it stands I’ve got a forged bottom end from when the engine received a fresh up and rebuild 1500km ago, Tomei Poncams (type B), 800cc injectors, Nismo fuel pump, PowerFC, Boost Controller, Nismo twin plate.
Ive got Tomei cam gears, Z32 AFM’s sitting on the shelf along with a 100mm thick intercooler as I had large HP aspirations for the car but I’m not sure that the trade off for lag would be worth it as the car is pretty much a street driven car. I had the HKS2530’s in mind as preference #1 followed by the 2860-5’s second behind but the -9’s are starting to entice me with the response benefits.
With my above mods what route would be best for my application?
    • I did a pretty ruthless clean up before I left townsville. If it wasn't a part to suit a car I currently have it was sold or binned. I have all my stuff organised in big tubs with lids that stack from supercheap and bunnings depending on who was cheaper at the time. Parts were sorted by either chasis/motor/Fabrication/general/electrical. I have a mezzanine that's 7mx2.3m and all lives up there. Easy to access when needed and out of the way.  I also have the issue of selling and dealing with scumplace/marketbook was actually going to list stuff today but couldn't be bothered as been stuffed around too much. I generally let a few people know I want to off load stuff and people pass it on to others to contact me, generally easy sale and I'm never looking to make big dollars. Rather it gets used than go in the bin. Next clean up will be around Xmas and if doesn't go on the s15 it's going bar 2 sets of wheels.
    • Did a little bit on the V37 today. I bought this LED kit out of the US https://www.ebay.com.au/itm/125953603618. Best I could find online but didn't look great, in the end the quality was pretty much right and it did come with locations for each light including rear number plate and a few spares. The factory owners' manual was also useful with information on where to pop each light out without damage. I prefer the LED look as I use it daily including at night and the LEDs are both brighter and the white light is easier to read with. Vanity mirror comparison, LEDs just look more modern The glove box was the only difficult one (and the only one that was previously blown.....), steps were Open glovebox 50% but not fully open Push up on bottom of the box to unclip it on both side, not screws or pins to remove Remove the top stays at an angle, right side then left, because.... Before dropping the glovebox totally, remove soft close clip on left Then, remove 7 screws to release the glovebox surround Twist the globe holder anti clock to release it from the surround In this case, the LED globe supplied was wider than factory and did not fit, so I ground down each side about 1mm then inserted it Last trick, start engine to check the LED polarity is correct, the globe only operates when the engine is running (whether the box is open or closed) I also moved the 4G booster and wifi across from the Fuga, a little frustrating as I could not find a good Accessories ACC source anywhere in the boot so I'll run a wire from the cabin next time I get a chance. Also, unlike the Fuga the external antenna wire does not quite fit between the rear windscreen and the body so I think I'll have to drill a hole in the roof to mount it. Probably not that interesting for most people so I'll just post once complete
    • Pretty sure I could do but it would need to be exported and reimported as the current import approval is race only. But in practice there are plenty of other practical reasons it can't be a road car despite their potential value these days like stripped interior looms, cage to cut out etc Nah, no mods to it other than updating the roll age to current regs. It makes about 350 (laggy) kilowatts on the N1s at 18psi which is enough to push it around the place
    • This is it, folks! Our final event of the year... The big one, you all know and love - Putty Road! It goes without saying, but this is the biggest cruise in our calendar each year! A nice long drive, with a hearty pub feed at the end! Do you need much more enticing than that!?!? So make sure you wash the car, get your cameras out, block out the calendar, and get ready! We know you're all as excited as we are, so make sure you lock in the details and date below: Date: Sunday 8th December 2024 Meet Location: Corner Windsor Road and Groves Avenue McDonald's / KFC (3 Groves Avenue, Mulgrave) Meet Time: Meet at 9:00am for a 9:30am departure Destination: The Royal Hotel, Singleton (84 George St, Singleton) Map: https://tinyurl.com/saunsw-puttyrd Itinerary: We will meet at McDonald's / KFC on Windsor road and from there will head onto Putty Road. There will be a break at the Grey Gum Cafe (8679 Putty Rd, Putty) which we should reach at approximately 11:30am. For all the Newcastle folks this will be a good point to join up. From here we will continue on to Singleton for lunch. Please remember to fill up prior to heading onto Putty Road. There will not be a fuel stop until Singleton. To those running on E85, Freedom Fuel (old United) at Vineyard on Windsor Road has started selling there. At Singleton there is a range of servo's available including BP, Shell and Caltex. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back by popular demand - we're lining up another Old Pac Run! Get your cars ready for one of the best night runs on the calendar! So without any ado whatsoever, here are the details for you to save: Date: Saturday 23rd November 2024 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: Meet at 7:30pm for a 8:00pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://tinyurl.com/saunsw-oldpac Definitely an easy one for this cruise, meet at Cowan Truck Stop and jump straight onto Old Pacific Highway! Final stop at McDonald's which has plenty of parking all around. Please be mindful of the added police presence lately so best behaviour is expected! There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
