Also buying 2nd hand AFMs is also wasted money. If they start to fail or play up, you end up buying new ones or chasing gremlins.
Nah Ash, you get out your stanley knife and $10 soldering iron and go to the SAU DIY section, grab a beer, read up and settle in to bodge it up.
The gtr came off the dyno at efi today. very happy with the results.
stock bottom end
Ported head with jun cams, springs etc.
gcg 35r on custom steampipe highrise with external gate.
750 cc jectas
Motec M8 puda
front mount etc.
made a stout 330 rwkw at 25 lb
Very smooth to drive and very happy with it.
Interesting to note that this setup is a couple hundred rpm laggier than the 37/88 on the 3 litre engine in the wheelchair.
ERD Dan is finishing off the catch can setup and then its rego time. Will be noice to have as a regular driver to take some k's off the other car.
ok im sure most of you have seen my threads/post on this topic but ive come across this and have read the thread start to finish.
Now, its point me in the right direction i just need to confirm a few things and would like constructive critisim .
Ok so the best place to start and give an idea of what im working with.
Engine: Rb26dett Rebuilt
ATI 600hp Harmonic balancer damper & pulley kit
N1 water pump
HKS oil pump
Tomei oil gallery orifice
ARP Head stud kit
Cometic Street Pro 87mm MLS head gasket
Nissan full gasket set
HKS step-2 valve springs
R34 Greddy N1 Street Special camshafts, R34 CAS
Ported & Flowed headwork
Greddy timing belt
Precision adjustable intake & exhaust cam gears
Drive key, tensioner & idler bearing kit
87mm CP Piston kit - full block tidy up
To add:
twins- From reading here its either -9's or 7's ( -5's i have thought about, But this is weekend street/hills/twsistys)
R34 Dumps
Front Mount to suit 2nd hand GTR most likely
split fires
ID1000's or sard 800's ( still need to read on this topic)
powerFC or nistune mabey even a vipec
Nismo AFM ( depends on ECU)
Jim berry clutch to match power
Forgot to mention is i will be using Keeping the GTS4 gear Ratios.
Now my aim is 350kw, pretty hesitant to chase big number for now and keep in mind this will be a street weekend car only, I walk to work and have a weekday run around
From what i gather and as some people would say simply -5's for power -9s for response and -7's for more resposne and a tad less power.
Im sure these figures can be made quite easy on a unopened block, And i have no doubt i can push some decent figures.
Idealy, Responsive -5's would be the choice for everyone, Though im assuming its just not possible as if so it would have been done before.
Any point in the right directions regarding the enigne build and supporting mods im going to be choosing?
ive got a few months before the work beings so im in no rush, I just want to do it once and do it right.
Edited by sydking
It's a process of elimination for this. -7's won't do 350kw, I've seen -9's reach 350kw (didn't have anything left to give) on a literally spare no expense build, -5's will get to 350kw without too much effort but as you should've read by now they get killed by 7's and 9's under 4500rpm, 5's really require a stroker engine.
It's not really hard, they all have their ratings and own characteristics-you need to decide for yourself which suits you best or on the flip side if you'll change your goal to allow a wider range of choices eg if you drop 30kw off your kw target you can have your choice of turbos.
Also if you havnt been in a car with that power before, don't get hung up on the number, there's 350kw cars that have such laggy power delivery that a well sorted 320kw one will have it most days. IMO you're better off with -9's and just run at 24psi and enjoy the result.
It's all well and good to say you've got a 350kw car but if it only makes peak power for 2000rpm it will be a shitbox to drive through hills and traffic even though it will feel fast due to the transition onto power. Food for thought
N1 water pump
HKS oil pump
ARP Head stud kit
Greddy timing belt
To add:
R34 Dumps
split fires
Injectors I would go the ID 1000's. I have had the Sard 800's and my ID 2000's drive and idle better than the Sard's ever could. That was on a PFC and LINK G4. They will be bigger than you need for sure.
ECU: By the time you buy a FC and Nismo AFM's, you're almost at the money for a Link or a VIPEC. Go the Link or Vipec.
Water pump: Use a standard one. Its been covered quite alot on here.
Clutch: Some people swear buy them, having driven a few i'm not a fan. Nismo twin plate everytime.
Also a cheeky mod that you may want to do is the "Twin Turbo pipe mod". Have a search.
Yer agreed, TBH i wouldnet know the diff between a 300kw and 350kw car, as ive never been in one, Im only using numbers as thats all i can make a decision on based of what i read.
Ideally i would like to take a ride in each, Who knows, everyone is difrent, I might even not notice a bit of lag to enjoy the soild up top power of the -5's
But RE PSI if i chose -9's 24psi Would be minimum for me
I'm currently running -9s on built motor and on a "75%" tune I am making 329awkw at 18psi...full boost at 3500rpm
I say 75% as the engine is still tight after run in and my tuner has recommended an extended break in stage and after all checks so far looking good
We will eventually be cranking the boost to 22-24psi
As piggaz stated go the ID 1000s I'm running them and idle better then the Nismo 600cc I had (unless you want them they are for sale :P)
And Nismo twin plate the only choose worth every cent
How long until the turbo choice is made? Give me a week or two and I will show you a -5's, although on a stroker, so not the best representation. Are you coming to Texi?
if you need a -9 comparison would be happy to help :thumbsup:
From memory the Nismo pipes are a little on the small side. Something like twin 60 mm into a 75 mm (I will double check when I get home). The HKS pipes which are twin 70 in to 85 are a much better option.
Had a search of this: came across a great post on GTR-OC for anyone that is interested.
http://www.gtr.co.uk/forum/84482-testing-modified-twin-turbo-pipe.html
Has anyone done this?? what are the benefits? is it a safe and clean mod or will it lead to other things.
They refer to a shuffling? one member states it as the chipmunk noise, is this referring to the noise of the BOV's (might be a really dumb question) the talking bovs. mine makes the ba ba ba ba ba noise if you hold on boost then ease off abit.. mates Gtr did the same thing, is this just how they are on stock bovs??
If its a viable mod might be keen to get one through GTROC..
any help would be appreciated.
    • Hi guys looking for a r33 Gtst stock exhaust asap in Melbourne have $$ waiting thanks
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
