Also buying 2nd hand AFMs is also wasted money. If they start to fail or play up, you end up buying new ones or chasing gremlins.
Nah Ash, you get out your stanley knife and $10 soldering iron and go to the SAU DIY section, grab a beer, read up and settle in to bodge it up.
The gtr came off the dyno at efi today. very happy with the results.
stock bottom end
Ported head with jun cams, springs etc.
gcg 35r on custom steampipe highrise with external gate.
750 cc jectas
Motec M8 puda
front mount etc.
made a stout 330 rwkw at 25 lb
Very smooth to drive and very happy with it.
Interesting to note that this setup is a couple hundred rpm laggier than the 37/88 on the 3 litre engine in the wheelchair.
ERD Dan is finishing off the catch can setup and then its rego time. Will be noice to have as a regular driver to take some k's off the other car.
ok im sure most of you have seen my threads/post on this topic but ive come across this and have read the thread start to finish.
Now, its point me in the right direction i just need to confirm a few things and would like constructive critisim .
Ok so the best place to start and give an idea of what im working with.
Engine: Rb26dett Rebuilt
ATI 600hp Harmonic balancer damper & pulley kit
N1 water pump
HKS oil pump
Tomei oil gallery orifice
ARP Head stud kit
Cometic Street Pro 87mm MLS head gasket
Nissan full gasket set
HKS step-2 valve springs
R34 Greddy N1 Street Special camshafts, R34 CAS
Ported & Flowed headwork
Greddy timing belt
Precision adjustable intake & exhaust cam gears
Drive key, tensioner & idler bearing kit
87mm CP Piston kit - full block tidy up
To add:
twins- From reading here its either -9's or 7's ( -5's i have thought about, But this is weekend street/hills/twsistys)
R34 Dumps
Front Mount to suit 2nd hand GTR most likely
split fires
ID1000's or sard 800's ( still need to read on this topic)
powerFC or nistune mabey even a vipec
Nismo AFM ( depends on ECU)
Jim berry clutch to match power
Forgot to mention is i will be using Keeping the GTS4 gear Ratios.
Now my aim is 350kw, pretty hesitant to chase big number for now and keep in mind this will be a street weekend car only, I walk to work and have a weekday run around
From what i gather and as some people would say simply -5's for power -9s for response and -7's for more resposne and a tad less power.
Im sure these figures can be made quite easy on a unopened block, And i have no doubt i can push some decent figures.
Idealy, Responsive -5's would be the choice for everyone, Though im assuming its just not possible as if so it would have been done before.
Any point in the right directions regarding the enigne build and supporting mods im going to be choosing?
ive got a few months before the work beings so im in no rush, I just want to do it once and do it right.
Edited by sydking
It's a process of elimination for this. -7's won't do 350kw, I've seen -9's reach 350kw (didn't have anything left to give) on a literally spare no expense build, -5's will get to 350kw without too much effort but as you should've read by now they get killed by 7's and 9's under 4500rpm, 5's really require a stroker engine.
It's not really hard, they all have their ratings and own characteristics-you need to decide for yourself which suits you best or on the flip side if you'll change your goal to allow a wider range of choices eg if you drop 30kw off your kw target you can have your choice of turbos.
Also if you havnt been in a car with that power before, don't get hung up on the number, there's 350kw cars that have such laggy power delivery that a well sorted 320kw one will have it most days. IMO you're better off with -9's and just run at 24psi and enjoy the result.
It's all well and good to say you've got a 350kw car but if it only makes peak power for 2000rpm it will be a shitbox to drive through hills and traffic even though it will feel fast due to the transition onto power. Food for thought
N1 water pump
HKS oil pump
ARP Head stud kit
Greddy timing belt
To add:
R34 Dumps
split fires
Injectors I would go the ID 1000's. I have had the Sard 800's and my ID 2000's drive and idle better than the Sard's ever could. That was on a PFC and LINK G4. They will be bigger than you need for sure.
ECU: By the time you buy a FC and Nismo AFM's, you're almost at the money for a Link or a VIPEC. Go the Link or Vipec.
Water pump: Use a standard one. Its been covered quite alot on here.
Clutch: Some people swear buy them, having driven a few i'm not a fan. Nismo twin plate everytime.
Also a cheeky mod that you may want to do is the "Twin Turbo pipe mod". Have a search.
Yer agreed, TBH i wouldnet know the diff between a 300kw and 350kw car, as ive never been in one, Im only using numbers as thats all i can make a decision on based of what i read.
Ideally i would like to take a ride in each, Who knows, everyone is difrent, I might even not notice a bit of lag to enjoy the soild up top power of the -5's
But RE PSI if i chose -9's 24psi Would be minimum for me
I'm currently running -9s on built motor and on a "75%" tune I am making 329awkw at 18psi...full boost at 3500rpm
I say 75% as the engine is still tight after run in and my tuner has recommended an extended break in stage and after all checks so far looking good
We will eventually be cranking the boost to 22-24psi
As piggaz stated go the ID 1000s I'm running them and idle better then the Nismo 600cc I had (unless you want them they are for sale :P)
And Nismo twin plate the only choose worth every cent
How long until the turbo choice is made? Give me a week or two and I will show you a -5's, although on a stroker, so not the best representation. Are you coming to Texi?
if you need a -9 comparison would be happy to help :thumbsup:
From memory the Nismo pipes are a little on the small side. Something like twin 60 mm into a 75 mm (I will double check when I get home). The HKS pipes which are twin 70 in to 85 are a much better option.
Had a search of this: came across a great post on GTR-OC for anyone that is interested.
http://www.gtr.co.uk/forum/84482-testing-modified-twin-turbo-pipe.html
Has anyone done this?? what are the benefits? is it a safe and clean mod or will it lead to other things.
They refer to a shuffling? one member states it as the chipmunk noise, is this referring to the noise of the BOV's (might be a really dumb question) the talking bovs. mine makes the ba ba ba ba ba noise if you hold on boost then ease off abit.. mates Gtr did the same thing, is this just how they are on stock bovs??
If its a viable mod might be keen to get one through GTROC..
any help would be appreciated.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
