Hi guys,
Im new to the forum.
Im looking to upgrade my 32 GTR to between 300-330awkw.
I already rebuilt the motor because i bought it with a run bearing.
Here's a list of mods already done: ( i know now that half the stuff isnt needed, but i was young and silly. Anyway im working with these bits
N1 block
N1 crank (grubscrewed, linished etc)
cp pistons
Argo rods
ARP head studs
Race series bearings
Tomei MLS head gasket
Tomei sump baffle and oil restrictor
Tomei poncams 260/9.15
Tomei springs
Tomei adj gears
N1 oil and water pumps
Gates belt
Light port head
Tomei manifolds
Mines dumps
Bathurst spec turbos (i think)
full exhaust
Thicker intercooler
std afms
std injectors
Probably other things those are main ones for now.
Bathurst turbos quite laggy so im very interested in the GTSSs. Are they worth the extra dosh over the 2860-9?
Also what do you think they are capable of with my engine. (forgot to mention its running 9:1 comp)
What sort of boost do these turbos stop performing at?
Sounds like the go is nismo afms and 700cc injectors? does this sound about right?
Its a street car above all so looking to be responsive.
I appreciate any wisdom you would care to share (any silly questions i apologise for im a newbie)
Cheers
Luke
Edited by piranha
You've got SO many parts there needed for 400kw, so why not aim a bit higher?
I'd be putting a set of -5's on there (cheaper than gtss/-9 also), run them up to 24 psi.
You havnt mentioned ECU
Go get some "ID1000" injectors by a company called Injector Dynamics. Their drivability (eg street manners) is out of this world good.
Yes NISMO AFMs will do the job
Sell the current turbos, they're laggy and for that lag won't pay off with power.
If you want response then the -9s are the choice, no doubt, for a 2.6ltr. I had them on my GTR. Swapped em out for -5s and the car is noticeably slower below 150km/h, very noticeable delay in between gears. Which is the stuff you don't see on a dyno.
Above 150km/h-200km/h+ though obviously its a different ball game. So if you want response as in - under 150km/h performance - then -9s are the choice.
Sard 700s and Nismo AFMs will suit perfectly. Mine made 24psi early and then fell away to around 18psi in the top end, making 340rwkw @ 7000rpm (around 19-20psi), after that it drops off. They come on @ 3300rpm nicely however so plenty of range to choose from.
GT-SS & Garrett -9s are identical. The HKS items are a waste of money... Here is something I prepared earlier
http://www.skylinesaustralia.com/forums/topic/254450-79s-or-5s-garretts/page__st__440
You can get -9s locally for around $2800-$3000. That's complete with gaskets ($100) & actuators ($250).
If you paid $450 for 2 actuators, then you were stung yet again. They are $250 from GCG every day of the week.
The HKS Kit costs $300 more before it even leaves Japan. Add freight, add Tax... Even conservatively you've paid $3700
All for what?
A spray-on HKS logo on the 2 actuators. That's it. There is no other difference.
The HKS Kit is only comparative when the dollar was above 95, which when it was - the HKS kit was a good buy.
Thanks for the info nismoid
Will have to have a good think before I decide.
Sounds like the -9s would be a godsend after living with laggy bathurst turbos for a year.
Decisions decisions
You made 24psi at 3300rpm, or they started making decent boost at 3300rpm? Impressive if full boost from 3.3k and makes peak power at 7k, thats a 3.7k spread of useable torque, don't see any turbos on rb25s that make that kind of power spread at >=300kw
thanks for the quick reply N1gtr
Yeh I suppose I probably should aim a little higher.
Its got a power fc (afm version).
Also got gts4 diff gears
Will the nismo pump handle 400kw?
Diff gears done aswel? Ok forget -9. They're Just a terrible choice IMO given the rest of the setup.
Don't get caught up in the lag difference between -9 and -5, you're probably thinking it will be a lag monster and suck from reading the threads on here, given your gearing and the rest of the setup stick 5's on there and enjoy your car.
Pump should be fine.
Power fc will also be fine.
Btw Nismoids car on 9's was stupidly quick through hills, havnt been in it since his recent turbo swap, but will soon.
So it's not like 9's are crap, I'm not saying that, I'm trying to say you've spent about 10k in parts which pretty much all will be a waste on those turbos (stock rebuild in stock block will be fine for 9's).
Where are you located? You could always meet up with some built GTR owners and go for a ride or two before making the choice.
^ you know there is a difference. You've been in my car & saw it come on like a cut cat around 3500rpm in 2nd. :P
Will take you for a belt next time I drive up, or you come down. You'll see what i mean about in/out of gear stuff.
It's just what one person calls big vs another.
That extra half second delay in between gears from the larger -5s is the most noticeable between the two set-ups and kinda gives me the shits a little.
The RPM band you can just adjust driving style and pick a lower gear etc.
He is in NSW, i checked - otherwise I'd have offered myself lol :D
No they start ramping up onto boost hard @ 3300rpm. Forget when it hit 24psi, I posted the graph(s) a while ago if it's a major concern.
Noticeably sooner than -5s either way.
-5s dont do much until 4000rpm but hold till 8000, my limit is set to 8300 and i hit it regularly so they still keep pulling.
Its pretty much the same power band to be honest. Its just a shift of 700rpm to the left really.
I never said anything about torque though... That progressively drops off, same as the -5s do.
Torque doesn't hold till redline.
Well that's cause we aren't talking about RB25's in here
Eg mine on 5's (before bearing let go) did 150rwkw at 3000rpm, 235rwkw at 4000, then maxed the boost (ebc was off and was running off the pussy actuators). It was well on it's way to the same sort of number as before but was making something like 5psi from the start of the run at 1500rpm which is just incredible to drive.
Anyway, back to GTRs, maybe this guy needs to be posting in the 400kw thread ;)
Cool thanks for that, a 4k power band is still impressive either way.
No doubt, it always seems to in turbo cars, just meant it held decent torque to redline (as peak power was made at 7k).
Haha of course, I personally don't have much experience with them, just trying to get my head around the different turbo configs and how they perform. It is my next upgrade when I get bored of my 32 with 25det
Edited by Rolls
Realistically it's probably closer to 3500rpm than 4000rpm given it's not always loaded in 4th - but still both turbo choices offer a good spread of power.
This is on PULP as well. E85 will improve it a little from results seen thus far.
Piranha if you're in Sydney, it's easy enough to get you a ride in a 300kw GTR and back to back in a 400kw GTR.
I promise you will want the 400kw one then once you've seen them back to back.
Good point Ash made about one person's idea of lag against another. For example you may get someone thinking a 2.6L and GTRS's is a good setup-in most peoples minds they'd say that setup is totally crap, but the owner may like it.
See what you like and go from there :)
Yep I'm in sydney. That would be good to gauge the different turbos.
I have been in an s13 with rb26 and -5s but it only weighed 1000kg. Just destroyed the tyres. can't compare it with awd gtr anyway.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
