Hey guys,
My R32 drift car decided it didnt want to start the other day (The motor is an RB25det) so i had a look today and found a problem.
first thing i noticed is my spark plugs were wet with fuel, so this tells me im not getting any spark. As i got to the last coilpack and spark plug i noticed alot of charcoal around that area of the valley. The spark plug was all sooty on the section where the coil pack connects, i then looked at the coilpack itself, the rubber boot was a bit warped and the previously blue silicon it was covered in is now brown. (I've coated all the coil packs in silicon to prevent waste spark.)
so there is a problem with this coil pack. But i still cant workout why the others are not firing? I checked the ground wire that connects to the rear coilpack bracket (the one that has been cooked). and the wire seems to be fine. If the back coil pack is screwed, the other coilpacks should still work thus allowing the car to start and run on 5 cylinders? or am i wrong?
VIDeO vv
cheers guys, any help welcome :P
Edited by zertek
https://www.sau.com.au/forums/topic/236474-coil-pack-on-fire/
If you have a multimeter check the output on the coil pack plugs to see if you getting 12V with ign on and constant earth, then crank it and see if your getting a firing signal earth from the ignitor.
I would agree that the ignitor is probably damage after that but. I don't think it has anything to do with the silicon you have used, just a coil pack gone bad. If you don't have a multimeter just rig up a 12v test light will do the same job.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
