Hi All,
Just thinking about the longevity of these spacer/liner kits and lack of cooling around the top of the sleave with a closed deck engine. The Kakimoto is only about 20mm thick which wouldnt leave much material to make it thick enough and allow for material to be removed to make it an open deck extension.
I have no idea about the thickness of the OS kits. There seems to have been 2 versions with diferent thicknesses.
Are these spacers really designed as more of a race only item?
https://www.sau.com.au/forums/topic/236477-kakimoto-and-os-spaced-blocks/
SK posted a pic of the thinner OS spacer not too long ago.
Yep saw it and it wasnt possible to tell if it was open deck or not as it was pictured the same way up as it is instaled on the engine.
If you were to get an engine block and cut it in 1/2 down the center of the cylinders you would see the cylinders are about 4-5mm thick, and coolant is able to flow around the entire cylinder. Only at the top of the block does it become a seemingly solid piece.
Around each cylinder are 4 slots that water passes through from the block to the head, then it flows through the head over the combustion chamber and out the water outlet that is mounted on the plenum.
When sleaves are inserted into the block the normal cylinders that are cast into the shape of the block are bored out to allow the sleave to be fitted to the block. The sleaves can be pressed in, or shrunk fit and slipped in. The result is that the sleave material is considerably stronger than the standard cylinder material. This is for 2 reasons. Cylinders liners/sleaves are spun cast or in some cases machined from billet steel, which means no porosity. When boring out a standard block there is no guarantee the wall thickness is 100% even the full length of the cylinder, and also there risk if finding porosity increases the thinner the walls get. Even if you cant see it, it could blow through to the water chambers the first time the engine is started if its over-bored too much.... ala cracked block.
The whole point of a spaced block is to allow a better rod ratio to be maintained when running larger stroke crankshafts. What it does it make the block taller, but so the pistons and rings dont catch on the join between the block and the spacer, liners are inserted through the spacer into the block. I think the Kakimoto spacers are more suited to the RB28 strokers. An RB28 with SR20 rods would be possible with a 16-18mm spacer and would produce a 1.75:1 rod ratio. Larger is possible though and I suspect that the RPMGTR RB29 is a Kakimoto spaced block.
Now with a closed deck spacer, if you consider that the thickness of a spacer is 20mm, add the top of the block thickness to that and you end up with an area that the sleave is not exposed to coolant, especially where it needs it the most... at the top where combustion temps and pressures are their highest.
An open deck spacer looks the same as a closed deck from the top. Its the under side where you will see its hollowed out around the sleaves so that coolant can flow around them and joins up with the 4 water galleries that surround each liner. This means the cylinder liner is getting better cooling at the top.
Thats as much as ive been able to learn about them. It seems to me that it is still a good way to go instead of the RB30DET/AWD conversion option for the a GTR. There wont be a lot of diference in cost (a few K perhaps), and it makes fitting a lot easier too.
The taller the block the more need for cooling. I figure a thin spacer might survive on the street (this is what I really want to find out about), and if it was alloy it might conduct enough the heat away from the cylinder liners.
saw this spacer kit on RHD website, 1.5k for the kit....using this method to achieve 2.8L would it be a more cost effective way or to the incressing of the bore size etc to get 2.8L.
be interesting to know as havent seen many people take this path, maybe not as good??
What would you require parts wise to make it a 2.8L??
http://www.rhdjapan.com/images/product/270...rmal/Image1.jpg
was looking at the pic from RHD, looks like open deck if my understanding of it is correct.
Edited by godzl1975
That looks closed to me. The water galleries around the cylinder go straight through to the head. The spacer is the same thickness at its thickest part as it is around the cylinder liner, so there is no coolant contact with teh liner where it runs through the spacer plate.
Thats a much better picture than anything ive been able to find so far too.
To make it a 2.8 it would only need the tomei/gt500/hks crankshaft. Then using sr20 rods and standard compression height pistons, or even rb30 pistons, 2.8lt is achieved. Becaused its sleaved they can be bored to 88mm to for a little more displacement.
Edited by Vspec R33
Thanks for that, very informative. I am loving your posts VspecR33 your journey to find out which path you want to take with your GTR is very interesting and it helps people like me who have no idea what they want to do just yet.
Good luck mate!
Mike
  • 3 months later...
The rare HKS 2.8L "High-Deck" bottom ends use a spacer and longer rods (possibly SR20).
It would make sense to use Sr20 rods. Common size, good rod ratio (1.75) with the 77.7mm crank. Im going to have a go at building one of these engines in about 6 months once other projects are out of the way. Custom sleaves and an open deck spacer plate fitted to a standard RB26 block for starters.
Im not chasing huge power with the project. I want response and drivability so I figure an RB30 crank/Sr20rod combination for starters. 9:1 compression and a limit of 8000 RPM will be fine. Probably GTRS's and a 1.5 bar tune. If it works well im contemplating making a cheap kit to allow someone with a blown RB26 to turn it into a 3lt relitavely cheaply.
Compare it to the expensive Jap stroker kits and it would be relatively cheap. Also, I guess if the local kit was made in significant numbers, I would imagine that the cost would be significantly lower.
Custom crank, SR20 rods, custom pistons, sleeves, spacer plate, block mods to suit. Better RS ratio than an RB30 and would rev to 9K+Also, I have heard of a Sydney workshop that has used a modified RB30 (or was it an RD28?) crank in an RB26. Also, Risking have an "RB29" kit usng the RD28 crank with 87.5 pistons.
I totally agree with you that the race pace method would be the best approach for ultimate performance. The problem is that all that custom work and parts puts the price tag up so much.
There is no middle ground with RB26/gtr modifications, and there needs to be. Its either keep it stock stroke and go to an 87mm bore, or throw three times+ more money at an engine rebuild project and step up to a 2.8. RB30 bottom ends have their issues as well. Mounting external accessories and that welding and re-drilling of the gearbox bell housing to acomodate the spaced sump adapter. Plus the height issues of the RB30 block, vs an RB26 spaced to use SR20 rods. Spaced/sleaved blocks would be used by everyone if they were just a cheaper.
The options work out to be as follows:
2.8lt high deck, 1.75:1 ratio, sr20 rods, 28mm rb26 pistons, 77.7mm crank = 14.7mm spacer
2.8lt high deck, 1.75:1 ratio, sr20 rods, stock rb26 pistons, 77.7mm crank = 16.7mm spacer
3lt high deck, 1.75:1 ratio, sr20 rods, 28mm rb26 pistons, RB30 crank = 18.35mm spacer
3lt high deck, 1.75:1 ratio, sr20 rods, stock rb26 pistons, RB30 crank = 20.35mm spacer
Im also considering using the chevy 5.4, 5.5 or 5.6 inch rod sizes as this provides more options with the rod ratio's. 1.61 - 1.67 is possible. Plus Chevy rods come in sets of 8 and are cheap as chips, were as you would have to buy two sets of SR20 rods otherwise. Chevy rods also support a larger gudgen pin bush so you could then use VG30 87.5mm pistons with 22mm gudgens and get a little more displacement.
All this is just calculations on paper and a few autocad drawings so far. Im a long way off making a prototype at this stage and am too busy with the rebuild of my other car and work in general.
  • 6 months later...
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
