  • 3 weeks later...
Thanks Rekin for the pics, you're a champ m8 ;-)
Mine had the exact problem as you've described. The servo arm dosen't move when I cycle through cold and hot. But when I wiggle the plug while doing that, the servo arm moved. So I tried taping up the wires, pushing the wires upwards, and all sort of other things.... but still have the same issue.
Eventually I was able to find a fix, the trick is to apply a slight pressure on the actual plug towards the right (back of the car). There is a rectangular void on the left of the plug and all I did was stuff some paper in there to create that pressure and the problem solved. I was able to get cold air again!! Bloody awesome. Thanks Rekin!
thanks to the both of ya! mine had the same problem but was stuck on cold even though ac doesn't seem to work but as it was stuck in the cold position so i didnt have heaters, so i too so stuck some paper in that gap and now they work perfect gunna save me on those early morniong starts in winter thanks again! guys
Hey guys,
I too am going through R32 air con problems. My servo motor is moving, I had my air con re gassed and serviced but no luck. I found a way to run the air con in diagnostic mod and the A/C does get cold in that mode... Just not in normal mode.
According to the following my outside sensor is causing the problems.
So if you need to test you sensors here is the instructions for Diagnostic mode.
Link:
http://skylineownersusa.com/forums/showthread.php?t=47
hope this helps.
just ran the diagnostic and came up with 25 so what is this senors purpose ? and what will happen or not happen if its not working? thx
  • 6 months later...
Big shout out to all who have contributed to this thread, thank you all, it has saved me a lot of time, sweat and my kids ears from swear words!!! Also found my mode motor had the same connection issues as the blend motor.
woah thread back from the dead
so anyway recently i turned my aircon on and it won't blow cold air it just blows ambient air at me, the compressor doesn't engage
every so often i can turn it on and it will work, but mostly not
from reading through some of these posts, it's either some kind of electrical fault or it needs regassing?
I'm far from an expert on all things air con but i'll have a go! If the clutch in your compressor only works every now and then it could be more an issue with the compressor (either electrical or mechanical fault) Have also read before that low gas levels can make the air con play up
Bumping too, it's summer, I 've prolonged not fixing the A/C as long as possible, but its FARKING Hot.
I'll give the paper in the socket a go, I juts want cold air, winter = drive with windows down
Btw, does anyone have problems with the "recycle air" button? Mine doesnt seem to want to stay on
is the demistor supposed to be able to be on without the air con?
because mine will only come on with the ac and the servo motor or whatever moves but it i select it to 32 degrees it doesent move as much as it does when im not in demistor mode and the air coming out wont be cold but it wont be hot and i need it to be hot to get over the pits.
any help appreciated cheers
quick way to check that:
puul the AC relay out and jumper it. there will be one terminal with +12v and another heavy wire that feeds to the clutch. if you connect the two the clutch should click.
last copule of these I have looked at were leaking on the front pipes. low gas = low pressure = no go as the pressure switch shuts the compressor off to save it destroying things.
btw - wave at a white signed combo van when it passes you on lutwyche rd of the morning about 730ish. (thats me!)
sorry to ask again but i was chasing some advice on this matter still
should be able to turn off a/c after selecting demist. but demist is hopeless with a/c running. but at 32 with a/c should still be hot
thanks i'll give that a go
yeah matey i've seen you around a few times recently in the morning, i nearly completely ploughed into the rear end of you a couple of weeks ago
you did the alarm on my car a couple of years ago when i was on hamilton road
ok if that is the case:
look at all the joins along the way to the condensor (outside coil) if any of them are dirty then your leak is there. most I haev looked at the leak is in the front right area (standing in front of car.)
it could just need regassing as i have no idea when it was last regassed and i've had the car for 3 years now and i haven't had it regassed and i know the owner before me was a complete noob that wouldn't have had it done
im pretty sure my ac just blows air(neither hot or cold, but as engine heats up it goes warm to hot understandibly as i noticed an ac pipe runs less than 10cm away from the belly of my turbo)
i came up with 23, 24, 25 on diag test.. i knew about th water temp as my gauge says nothing all the time.. but what are the other 2? is it just simpls enuf as replacing them and my aircon works? :S also i havent done any of the other checks as yet
thanks in advance!
  • 1 year later...
  • 4 years later...
Very useful writeup.
In addition to holding the socket in place with some paper, I found that some cabling had been zip tied in such a way that it was inhibiting the movement of the rod connected to the servo arm.
blast from the past.
Ended-up pulling out the blend-door servo motor and resoldering the tracks. Problem solved :D
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
