Just done a bit more reading and found out it may be the magnetic clutch or the fuse, but the fuse layout on the box is all written in Jap so if anyone has a layout of the fuses for an R32 so I can workout which fuse is the one for the a/c that would be great. I have been searching on here for a fuse layout but having no luck
Can you read this;
I got the sticker from ebay - worth having.
IIRC its the top row fourth from that right that blows when the mag clutch dies. IIRC the winding is supposed to be 3.5 ohms - mine was half that and blowing fuses before i replaced it. If you dont hear the clutch throw with a click when you turn the AC on, its a good place to start looking.
Hey guys,
I too am going through R32 air con problems. My servo motor is moving, I had my air con re gassed and serviced but no luck. I found a way to run the air con in diagnostic mod and the A/C does get cold in that mode... Just not in normal mode.
According to the following my outside sensor is causing the problems.
So if you need to test you sensors here is the instructions for Diagnostic mode.
Climate Control Diagnostics R32
The climate control has a diagnostic mode.
Enter the diagnostic mode by pressing the OFF button for five seconds within ten seconds of turning the ignition on.
Sensor check
Sensor check is selected by pressing HOT switch (the red triangle) while in diagnostic mode. The microcomputer detects whether each sensor input signal is within correct parameters. The results are displayed on the screen.
If normal, a "20" is displayed.
If abnormal the failed sensor number is displayed. The sensor numbers are as follows:
20 - all is normal
21 - outside air sensor
22 - Inside air sensor
23 - Water temperature sensor
24 - Intake temperature sensor
25 - Sunload sensor (small sensor on the left hand side of the dashboard near the windscreen)
26 - PBR
27 - Refrigerant temperature sensor
This should tell you if any of your sensors are faulty
Link:
http://skylineownersusa.com/forums/showthread.php?t=47
hope this helps.
Since buying my car about 4 months ago the a/c has never worked. with the recent heat wave I thought i'de better do something about it. Put it into dianostic mode and came up with 25 and 27. 25 as expected. the sensor relating to 27 kept fluctuating from -30 to 0 and +30. I disconnected and bridged the connections which gave me a constant 46 degrees. You hear the a/c switch to full mode but the compressor does'nt kick in. After further investigation I discovered that the 2 electrical connections on the compressor were disconnected to I reconnected them thinking this was the problem but it made no difference. I've checked all fuses which appear ok, so I disconnected the plugs again to check the voltages. The plug with the 2 wires read 0.2 volts each to earth. The single cable plug read 0.045 volts obviously no where near enough to make a compressor work. Does this pressure switch cut power to the compressor? If so can you bypass it so I can at least see if the compressor works. Also does this sound like a no gas situation.
Sorry for the long post but really need to do as much of the investigation myself before taking to be re-gassed.
Ok so i'm going to answer my own questions. Guess I should have done a bit more investigating first. After reading a few more posts I went and checked the pressure switch which was ok. Followed back to relay. Bridged the connections and hey presto A/C now works. Incidentally the relay next to it that controls the thermo fan which is the same is also knackered. Hence why I've never heard it come on even on 42 degree days. So looks like I'll be getting 2 new relays tomorrow.
My problem is no air is comming out from the face vent or foot vent no matter which position i set it at air is just coming out from the front glass area onli
wats the go wif that
the thing is i got a guage in the side face vent so they must of did something to stop air coming out from the vents
Edited by Godzilla_400R
i too am having problems trying to get my ac working too, just would like to know if with ac on does clutch engage and stay on and not come on and off like other cars, if that makes any sense. any help much appreciated
Thanks Rekin for the pics, you're a champ m8 ;-)
Mine had the exact problem as you've described. The servo arm dosen't move when I cycle through cold and hot. But when I wiggle the plug while doing that, the servo arm moved. So I tried taping up the wires, pushing the wires upwards, and all sort of other things.... but still have the same issue.
Eventually I was able to find a fix, the trick is to apply a slight pressure on the actual plug towards the right (back of the car). There is a rectangular void on the left of the plug and all I did was stuff some paper in there to create that pressure and the problem solved. I was able to get cold air again!! Bloody awesome. Thanks Rekin!
oops double post
Edited by Marko R1
this is great info - i had similar problems where my air mix actuator for the foot area would get stuck & wouldnt allow me to go from cold>hot & vice versa.
when i ran my diagnostics the error in 'step 3' as per workshop manual appeared as number '34' which stated it was the air mix door that controls the foot area...i will try the piece of paper or zip tie trick to see if that works as the servo runs when it feels like it.
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
