Item: Garret t04e huffer!
Age: .. about 2000k on it
Condition: VERY Good
Price: $600neg
To Fit: A car!
Contact: 0424 193 992 (pls ring after 5pm WA time)
Comments:Turbo is in VERY good condition. Pulled it off last night. Checked it out, no shaft play, no damaged blades etc.
Compressor: .7 A/R, 4" inlet, 2.5" outlet
Exhaust: 1.15 A/R, 3" outlet
This turbo is a 60mm trim with a T4 footprint
Reason for sale is I have a larger turbo
Thanks! offers welcome!
https://www.sau.com.au/forums/topic/236503-fs-garret-t04e/
hey mate
what car was this turbo on before and what sort of power were you making on what psi?
Definately interested also how much to post it to 5107 South australia mate
thanks
krishy
https://www.sau.com.au/forums/topic/236503-fs-garret-t04e/#findComment-4142827
it was on a fc rx7, i managed to make 333wrhp @ 13 psi
i just got a 18kg turbo posted to me from eastern states for $53
so i guess $35 should cover it.
hmm no idea why pics are so small :\ trying to use some funky upload site
also, regarding wheel sizes, i believe they are very similar to gt35..
Edited by Jezzza
https://www.sau.com.au/forums/topic/236503-fs-garret-t04e/#findComment-4143803
$500 for a BIGGER Garret TO4E turbo with NO shaft play, has seen a max of 13psi over about 2-3000kms!
it will be fully sick on a rb25det
proven to make 330+wrhp @ 13psi on my rotor.. imagine it on a 2.5L pushing closer to 18-20psi :mellow:
very similar wheel sizes to the gt35's btw :rant:
https://www.sau.com.au/forums/topic/236503-fs-garret-t04e/#findComment-4156515
a few ppl been asking me what they would need to use this turbo..
I DONT KNOW! IM SORRY!
i do not know what is on your car, ot what is needed. i have given info for you to find out
https://www.sau.com.au/forums/topic/236503-fs-garret-t04e/#findComment-4159581
  • 2 months later...
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
