Item: Garret t04e huffer!
Age: .. about 2000k on it
Condition: VERY Good
Price: $600neg
To Fit: A car!
Contact: 0424 193 992 (pls ring after 5pm WA time)
Comments:Turbo is in VERY good condition. Pulled it off last night. Checked it out, no shaft play, no damaged blades etc.
Compressor: .7 A/R, 4" inlet, 2.5" outlet
Exhaust: 1.15 A/R, 3" outlet
This turbo is a 60mm trim with a T4 footprint
Reason for sale is I have a larger turbo
Thanks! offers welcome!
https://www.sau.com.au/forums/topic/236503-fs-garret-t04e/
hey mate
what car was this turbo on before and what sort of power were you making on what psi?
Definately interested also how much to post it to 5107 South australia mate
thanks
krishy
https://www.sau.com.au/forums/topic/236503-fs-garret-t04e/#findComment-4142827
it was on a fc rx7, i managed to make 333wrhp @ 13 psi
i just got a 18kg turbo posted to me from eastern states for $53
so i guess $35 should cover it.
hmm no idea why pics are so small :\ trying to use some funky upload site
also, regarding wheel sizes, i believe they are very similar to gt35..
Edited by Jezzza
https://www.sau.com.au/forums/topic/236503-fs-garret-t04e/#findComment-4143803
$500 for a BIGGER Garret TO4E turbo with NO shaft play, has seen a max of 13psi over about 2-3000kms!
it will be fully sick on a rb25det
proven to make 330+wrhp @ 13psi on my rotor.. imagine it on a 2.5L pushing closer to 18-20psi :mellow:
very similar wheel sizes to the gt35's btw :rant:
https://www.sau.com.au/forums/topic/236503-fs-garret-t04e/#findComment-4156515
a few ppl been asking me what they would need to use this turbo..
I DONT KNOW! IM SORRY!
i do not know what is on your car, ot what is needed. i have given info for you to find out
https://www.sau.com.au/forums/topic/236503-fs-garret-t04e/#findComment-4159581
  • 2 months later...
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
    • I thought you didn't let mechanics, especially those with no idea, work on your car any more? Wouldn't that mean it won't be an issue in your case?
