I would like a really clean photo of the side badge off the R35. Straight on shot.
I have this one but if you look close there is a bug sitting on it.
Photoshop, mate...photoshop.
Hows this?
Bug> What bug???
Farkin Ace mang!
cept...well...you know that dust you can see around the top edge of the badge,....???? :)
Reckon you could magic that away too, bruv?
with the right money.. anything is possible...
Money cant get past the law for the common citizen...
Im 100% sure it was a Personal Import.
There is no other way.
Makes sense...the cars been here in Tokyo for over a year now...i was at the Tokyo motorshow for the launch...
I can 1,000,000% assure you it is not a personal import (number one fact it is a 2008 build, number 2 fact you have to own the car in Jp for over a year {or is it 2 years now?}). The import has been approved by RCVS and there are only 1 or 2 workshops in Aus that can bring in 25 each. All of the plates have already been allocated as far as I know, but for some reason this plate was issued quicker than the others, as bureaucratic red tape is holding issue of plates up. There are probably cars sitting in workshops with all the compliance work already done, just waiting for the green plate.
RVCS approval (click)
Under the RCVS approval you HAVE to buy the car direct from Nissan Jp (so anyone who brought one in prior to the ruling cannot comply it) and the car has to be brand spanking new (under 20 kilometres). International Motor Group had the compliance done by GT Compliance on this one, and they are well known for getting things done first.
You can buy one from these guys (click)
There is someone hocking complied ones on Car Sales, but the price is too cheap - so not sure what that is all about.
R35GTRs for sale
edit regarding this comment :
Mate, have some common sense - anyone who is anyone knows the R35GTR was released December 6 2007 .... whether they were 'launched' at the motor show or not.
lol, I'm 100% sure you are 100% wrong. This may shock you, but things happen in the world you may not know about. That car was imported eariler this year to sydney as a test car. It was complied and registered in Sydney and then sold to a buyer in adelaide. it is not a personal import so I don't know how you got to be 100% sure of that...
Well come on then - go out there are try to bring in for yourself an R35 without going by the regulations.
Youre regular enough surely?
While I wasn't specifically talking about car importation (although I have no doubt that you could do it with enough cash and knowing the right people) the simple fact of the matter is that your comment "Money cant get past the law for the common citizen..." is proven wrong every week, inside (and out of) our courtrooms :thumbsup:
...and anyway it appears that the Baron has cleared up the matter.
I was so hoping this thread was just going to go away quietly... :thumbsup:
I saw Jasons pic of the car in sydney but didnt click on it being sold to Martin.
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
