Iv been thinking of making something like this for my car at tafe. Im studying mechatronics & robotics, so this is right up my alley :P
If you use a manualised auto like the one that was in my car (click on link in my sig), this setup would be great.
https://www.sau.com.au/forums/topic/236562-shift-kit/#findComment-4140981
I found this on google, its one of their old designs, but you can see how it all goes together.
http://images.google.com.au/imgres?imgurl=...l%3Den%26sa%3DN
Howie It would be pretty easy to make up a couple of aloy paddles attached to some micro switches. it would all work on the stock triptonic.
I could look into making something like this for you if you would like.
https://www.sau.com.au/forums/topic/236562-shift-kit/#findComment-4142713
You bet your ass i'd be interested. So would most of the guys using the Stagea/R34 Tiptronic... keep me posted buddy :down:
Ok Ill let you know when Iv got something. I know what you mean about the stock buttons too, my brother has a S2 Stagea and the buttons arent the greatest.
https://www.sau.com.au/forums/topic/236562-shift-kit/#findComment-4142752
the fact that there is no physical link between the 2 freaks me out a bit.. relying on a RF link to swap gears just leaves me a bit paranoid!
I reckon you would be better off spending the $$ and getting a MV auto shift kit
I have an MV Autos shift kit. But it would be nice being able to shift it quietly and easly, plus if you convert to a full electronic shift you could fit a manual style shifter with two sensors for a sequential shifting as well.
But I agree, the RF freaks me out to.
https://www.sau.com.au/forums/topic/236562-shift-kit/#findComment-4143150
knox automatics, 395 installed, want in soft, chuck it in snow(i do in traffic so it doesnt go 1-2-1-2-1-2-1--21-2-1-2-)
Yer I know about that, what Im saying is when the auto is fully manualised like mine (see the video in my sig), the ratchet is very noisy and is sum what hard or heavy to change gears on a daily basis. If you could use an elecrtonic actuator to change it would be silent and easy, it just makes sense to run it this way (if you are fully manualised).
https://www.sau.com.au/forums/topic/236562-shift-kit/#findComment-4144214
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
