tridentt150v Posted October 21, 2008 Share Posted October 21, 2008 I brought a neat black plastic switch and wired mine up so that I can turn it on or off, too easy and looks factory. Link to comment https://www.sau.com.au/forums/topic/236588-how-to-stop-the-door-open-beep/page/2/#findComment-4208818 Share on other sites More sharing options...
OzCarImports Posted October 21, 2008 Share Posted October 21, 2008 I brought a neat black plastic switch and wired mine up so that I can turn it on or off, too easy and looks factory. Thats full pro, good idea! Link to comment https://www.sau.com.au/forums/topic/236588-how-to-stop-the-door-open-beep/page/2/#findComment-4208861 Share on other sites More sharing options...
riggaz Posted October 22, 2008 Share Posted October 22, 2008 this is probably seperate but to stop the 'lights on door open' beep I simply unplugged it.. However now I always leave my lights on ! Link to comment https://www.sau.com.au/forums/topic/236588-how-to-stop-the-door-open-beep/page/2/#findComment-4211594 Share on other sites More sharing options...
steve33 Posted October 23, 2008 Share Posted October 23, 2008 hey just did mine, different way though.entry is via the small pull out section near bonnet release. on the right hand side, under the steering wheel is a black box with 'smart entry' on it, size is about 4cm by 7cm undo 2 screws to take the box off the holding bracket. take out white plastic plug from box. (sticks in there pretty good) the black surround around where the plug went comes out, you will see where u can put in a screwdriver to jimmy it out. take out the circuit board. match up where the actual beeper is from where the audio holes are on the side (it is a round black cylinder abour 5c piece in diamater and 10 cm high) CAREFULLY either: 1- prize it off with a flathead screwdriver and pull out the terminals with some needle nose pliers gently (i did it this way easily) 2- get a solder iron and reheat/undo the conection from the back put everything back the way you found it this way it wont phuk with you alarm or windows or anything else, cos everything is as it was, just no noise cos obviously no beeper btw car was a r33gtst S2, should take about 20 mins max, have fun thats what i did. works a treat. left my headlight on once tho lol Link to comment https://www.sau.com.au/forums/topic/236588-how-to-stop-the-door-open-beep/page/2/#findComment-4214221 Share on other sites More sharing options...
R34Liner Posted November 9, 2008 Share Posted November 9, 2008 Here is my tutorial on how to remove the beep for a R34 - i acctually remove a plug straight from the ignition drum - it should be the exact same concept for r32 - r33 's and you also keep the beep for when you leave your lights on and open the door (which is very handy) - it doesnt effect your alarm or windows or mirrors or anything else expcept for when you leave the keys in and open the door!! D.I.Y - Tutorial - Get rid of R34 beep > http://www.skylinesaustralia.com/forums/Di...ep-t242701.html <h Link to comment https://www.sau.com.au/forums/topic/236588-how-to-stop-the-door-open-beep/page/2/#findComment-4250172 Share on other sites More sharing options...
Dhiv-Zilla Posted January 7, 2009 Share Posted January 7, 2009 ever tried just shutting the driver door? LOL Link to comment https://www.sau.com.au/forums/topic/236588-how-to-stop-the-door-open-beep/page/2/#findComment-4354407 Share on other sites More sharing options...
Dhiv-Zilla Posted January 9, 2009 Share Posted January 9, 2009 Actually I just figured out how to do it.. There's a button near the door weld - where the actual locking mechanism is for the door. I pushed that in and it worked a charm - i just used some masking tape Quick and easy Link to comment https://www.sau.com.au/forums/topic/236588-how-to-stop-the-door-open-beep/page/2/#findComment-4357689 Share on other sites More sharing options...
Jack88 Posted January 10, 2009 Share Posted January 10, 2009 you do realise now that if someone takes a fancy to your car and decides to steal it when they brake the lock and open the door your alarm wont go off? that button you taped up is the door trigger lol! Link to comment https://www.sau.com.au/forums/topic/236588-how-to-stop-the-door-open-beep/page/2/#findComment-4359847 Share on other sites More sharing options...
W1ngnut Posted January 13, 2009 Share Posted January 13, 2009 Hey guys, Just checked out the wiring for this door beep on my R33 Series 2. The black with purple stripe wire is correct with the first post, however I did it a different way that required no cutting. On the ignition barrel, there are a couple of wires going into a clip that directly plugs to the barrel and there are 2 wires that appear hard wired to the barrel but about 5 - 10cm down there is a clip for them (a bit like a fly lead). The first plug is for the lights so don't touch that one. The one on the side that has the sorta flylead is the one you want to unclip (for the r33 s2 it was a black flat plug). All headlights, power windows and mirrors still work. Link to comment https://www.sau.com.au/forums/topic/236588-how-to-stop-the-door-open-beep/page/2/#findComment-4366308 Share on other sites More sharing options...
Dhiv-Zilla Posted April 19, 2009 Share Posted April 19, 2009 Thats why I said, push it in and hold it with tape while work and then take it out... No wiring and etc etc Link to comment https://www.sau.com.au/forums/topic/236588-how-to-stop-the-door-open-beep/page/2/#findComment-4543321 Share on other sites More sharing options...
stefan-w Posted May 27, 2009 Share Posted May 27, 2009 (edited) i should also add that in a series 1 its to the left hand side of the glove box housing,not in the same place as the series 2's. check my tut for the series 1 version. I got to doing this today on my S1, the 'smart entrance' box is indeed behind the glove box housing... Removed the glove box, unscrewed the six Parkers, and disconnected the wire on these shitty pictures; If you just unplug it, and take off the black plastic cover, remove the piece of plastic locking the connector in the plug, and remove the lower left and right wires on the side of the small connector. Lower left being the green wire triggering the auto-lock for the passenger door, and lower right being the black/purple-ish wire for the door-beep. Edited May 27, 2009 by stefan-w Link to comment https://www.sau.com.au/forums/topic/236588-how-to-stop-the-door-open-beep/page/2/#findComment-4621253 Share on other sites More sharing options...
j_dewhurst Posted May 28, 2009 Share Posted May 28, 2009 Hooray. Ive finally worked it out. You know the beep that happens when youre trying to work on your pride and joy and listen to some music with the door open and all you can hear is the "beep beep beep". Well I found the control box to fix it You have 2 options to fix this. 1. Get a ridiculously loud sound system, and annoy the neighbours... or 2. Cut a wire. I went for option 2 because I like my neighbours. Located under the dash on the drivers side is a little black box labelled "smart entrance". There is a black wire with a purple stripe on it. Cut it and wrap electrical tape over the ends. Thats it. This does not mean that when you leave your lights on you wont get that beep, you still will. Thanks to Jack88 for informing me of the colour of the wire. This is my first DIY so I hope it is helpful and not pathetic!! Cheers, Jase. thanks mate i really interested in that 2 thanks for the pics Link to comment https://www.sau.com.au/forums/topic/236588-how-to-stop-the-door-open-beep/page/2/#findComment-4621622 Share on other sites More sharing options...
MUZZ27 Posted June 1, 2009 Share Posted June 1, 2009 easiest way i done it is take suround off ignition barrel and there is 2 red wires attached to the barrel unplug that black plug and no more door beep and the beep still works with the lights on as well. Link to comment https://www.sau.com.au/forums/topic/236588-how-to-stop-the-door-open-beep/page/2/#findComment-4630143 Share on other sites More sharing options...
