I currently have a rb20e in my R33. What can I say I picked the car up for only $1,200 us dollars here in Japan. Well I came across a guy who is selling a rb20det for only $150 OBO with no harness or ecu. So I was wondering if the wiring harness for the RB20e would work for the rb20det or is the wiring harness's completely different? I already know for sure I would have to pick a r32 rb20det ecu. Another thing is I also found a RB25de neo with harness and ecu for $200 firm, but wasn't sure if the rb20 trans would work on the rb25 neo. So what should I swap to? If I was to get the rb25de neo and boost it, could I use the rb25de neo ecu? Any help would be appericated.
https://www.sau.com.au/forums/topic/236598-rb20e-to-rb20det-or-rb25de-neo/
either of those would be better than what you have, but I would preffer the RB25de NEO over the RB20 for sure.
especially if you are going to turbo it.
there is a how to guide int eh N/A section of these forums.
the 20det will be too laggy behind the heavier R33 shell.
    • Interesting....can't say I've ever checked it, have always just changed it in the off season as practice
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
