Item: R33 gts-t series 1 1993
Condition: Mechanically sound good compression from test, damage to passenger side rear quarter panel (thanks to some asshole in a ute while it was parked >.<), drivers side window motor dead also. 187 XXX kms on the clock. Interior is great for its age.
I have owned this car for 3 yrs now and havent had anything majorly wrong mechanically. I had all the belts changed and new water pump when I first bought it and that was all done at 153 XXXkms. It has since been serviced regularly at 5000kms. It has new power steering rack from fulcrum, Exedy HD clutch and lightened flywheel only done about 12 XXXkms ago.
Has 2 new federals on the front tyres but needs new rears, I dont really have time to get a safety cert so thats the reason for selling unreg, it is still registered at the moment if youd like to come look at it.
Price: 7,000 as is unreg.
Whats it got: Monkey Warehouse FMIC, HKS super drager exhaust 2.5in from turbo 3in from cat, HKS SSQ BOV, Apexi Boost guage, Pioneer MP3 head unit and speakers, Coustic amp and Sony sub. 34 GTT rims
Reason for sale: Loss of job and now need a ute for new line of work
Contact: Send PM
https://www.sau.com.au/forums/topic/236619-fs-r33-1993-series-1/
Contact: Send PM
Also has Tein Coilovers in it
  • 3 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
