I was just having a look under the beast just earlier and I noticed on the underside of the muffler or whatever on the back that it says 'Nissan' and underneath it, it says 'Calsonic'. I'm just wondering if everyone elses stock one is like this or iv'e got some special exhaust and I didn't even know.
It just striked me cause I know in the JGTC that there is a Calsonic Skyline and maybe iv'e got one from their tuning house or something :Paranoid:.
https://www.sau.com.au/forums/topic/23663-calsonic-skyline-exhaust/
well one tip is actually closed off with a butterfly valve and im not sure but maybe at high revs the valve opens to let more flow through or sumthing??? beats me really, i never tested mine out cos its hard to have sumone looking at the exhaust closely and not dieing lol. When u get a new exhaust that cable can just be tucked under the heat shield (where mine is now) i reckon im gonna take the motor out cos its useless really!
i have asked so many people what that little motor thing in the boot before and no one could ever give me an answer, thank you for solving my most unsolved mystery of my skyline, haha, not that it matters as it came disconnected cause my car came with an aftermarket exaust but i still wondered what it was.
that cord thing for the exhaust is adjustable as well.
Mine opened up mid range, about 4000ish rpm.
It was designed so you could adjust your exhaust noise and all other exhaust matters.
Also, your radiators and things should be calsonic too !! :D
They make radiators and exhaust etc...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
