  • 3 weeks later...
  • Replies 42
Hey mate
id be intrested in: (depending on condition)
Your brake Master, Alternator and FMIC.
Willing to pay $400 + shipping - Dont know if this is a reasonable offer or not, no idea what their worth sorry.
Let me know
Regards
Ian
wtf? i cant edit?
Anyway, never mind on the brake master, turns out mines fine was another problem which i have now fixed.
Revised offer: 300 for alternator and FMIC. Will need pics of the FMIC and a guarantee the alternator is working.
  • 1 month later...
Hey Risking, can you PM me your number again, if I had it today, I would have been able to get some parts from you, but couldn't find the number...
Cheers mate.
Brian.
Both front windows are sold and gone but I do still have the regulators and the window motors yes.
They are still in the doors and in storage but if you need them I can probbaly get them out by the middle of the week.
As far as im aware the GTR will have the same door windows and presumable regs/motors as the GTS-t
Brad...
Edited by Risking
Regulators and motors now sold.
Still heaps of trim and stuff to go.
I now have a late model dash cluster and center gear stick section for sale.
Still have pillar trims, loads of engine bay spares, stock suspension arms
Tein coilovers
Center console and ash tray were sold a whole ago. And the reverse lights went to Charlie ages ago too.
Roy ill double check your parts tommorrow, the light globe in the storage room blew tonight so cant do it now.
still got the A pillar trims?
Yes I do.
Make an offer
still got the bonnet?keen as
Yeah I have a good condition grey bonnet
sent pm about drivers door mirror if u have it and if its gun metal gray
Sorry keeping the mirrors for now
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
