  • 3 weeks later...
  • Replies 42
Hey mate
id be intrested in: (depending on condition)
Your brake Master, Alternator and FMIC.
Willing to pay $400 + shipping - Dont know if this is a reasonable offer or not, no idea what their worth sorry.
Let me know
Regards
Ian
wtf? i cant edit?
Anyway, never mind on the brake master, turns out mines fine was another problem which i have now fixed.
Revised offer: 300 for alternator and FMIC. Will need pics of the FMIC and a guarantee the alternator is working.
  • 1 month later...
Hey Risking, can you PM me your number again, if I had it today, I would have been able to get some parts from you, but couldn't find the number...
Cheers mate.
Brian.
Both front windows are sold and gone but I do still have the regulators and the window motors yes.
They are still in the doors and in storage but if you need them I can probbaly get them out by the middle of the week.
As far as im aware the GTR will have the same door windows and presumable regs/motors as the GTS-t
Brad...
Edited by Risking
Regulators and motors now sold.
Still heaps of trim and stuff to go.
I now have a late model dash cluster and center gear stick section for sale.
Still have pillar trims, loads of engine bay spares, stock suspension arms
Tein coilovers
Center console and ash tray were sold a whole ago. And the reverse lights went to Charlie ages ago too.
Roy ill double check your parts tommorrow, the light globe in the storage room blew tonight so cant do it now.
still got the A pillar trims?
Yes I do.
Make an offer
still got the bonnet?keen as
Yeah I have a good condition grey bonnet
sent pm about drivers door mirror if u have it and if its gun metal gray
Sorry keeping the mirrors for now
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
