  • Replies 260
problem with sa car scene is its too full of big headed wankers, which makes things like SCS fail, because everyone takes the attitude of 'rice this, autosalon that'. if you dont have the right offset then how can you be in a car show?
SCS is(was) a good thing for Adelaide, admit it, any car show in Adelaide is a good thing and can only help the scene, the people in the scene is what lets it down.
+1
Thats so true. Everyones bagging out each other's car whinging about this that etc... people were complaining about the car scene dieing in Adelaide earlier this year and when something like this comes up everyone whinges about this and that AGAIN! Its not the organizer's fault that the car show is dieing more and more every year - its because everyone goes around bagging out the show and the cars; in turn making people less incline to want to go or want to enter! Its up to the car enthusiast community to provide the cars for the show AND attend aswell as spreading the words about it... NOT have the attitude of "oh my cars too good for SCS I'm not putting my car in that rah rah rah" + "oh I'm not going to SCS its crap compared with rah rah rah" + "Everyone dont waste your time at SCS its rubbish rah rah rah"...
I'm not pointing this specifically at anyone but more in general theres just too much bad mouthing this and that... wheres the love!?
i agree its most peoples attitide that wreck a good car show atmosphere,
but hey, its the way it going to be.....
thats the world today.
i never got to experience the car culture before it turned sour, hell, i have NEVER had the opportunity
to run any of my cars down the drag strip...
is this the way our kids are going to enjoy there cars?
this seems like the new school mentallity
^^ agree with the comments posted above.
20 bucks for a day out at glenelg, then if you get bored you can go for a drink or swim, and not get sunburnt or couped up in a tent like previous years, plus you get to hang out with your club buddies and check out the other clubs... i don't see any downsides to this event. It should be as good as AJD, if not better.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
