  • Replies 260
Not surprise you'd write a bad review considering you intended not to like SCS in the first place therefor not giving it a chance...
For me that DID enter I found it an enjoyable day - caught up with mates from other car clubs, met people and caught up with fellow SAU-ers. Plenty of nice cars there to check out and plenty of crowd from what I could see - definitely more cars and more people than this year's AutoSalon. Got some good shots too - will have em up shortly.
SCS is not my prefference. I don't like the scissor doors and 22" Vault chrome rims on WRX's. Just my opinion mate. As I said, I enjoyed the Skylines down there and the other tough cars (Steve's S13 and PureSX 180) but, overall, it was a poor blatant copy of AJD just smaller crowds and smaller amount of cars on show. Having some tool cranking music out of his car at the show while sitting in the car giving people the "Look at me, I'm so tough" look isn't cool.
Just my opinion - there's plently others who hate/love the show. Everyone on here is entitled to their own opinion on the show. Even if I entered the show, I would have posted the exact same opinion.
Just like Autosalon - it's a love/hate show.
So all in all disapointed?? Im just sussing some pics out atm and doesn't look like to bad a turnout!!
How was the cop situation today?? No defecting of cars in the carparks or anything???
Cops on horses, cops on bikes circling Jetty road and apparently a defect station was setup just past the oval later in the day!
was that some dudes behind SAU? Yeah.. me and trdz decided to drown them out with our own bass, and they gave us a wtf look LOL
Yeah it was either those dudes or the ones next to him.. i wasn't sure who's car it was coming from. But they all turned around and gave me and trdz a death stare at the same time.. it was rather intimidating LOL
Anyhow, we showed SAU +1 for sound-offs lol
We seriously needed more cars in the display.... if we had 16 or so like we did last year then we'd literally have taken up an entire row :P
Phu's RX8 was tasty, and Bruce's widebody S15's awesome too.. but the RX7's were porn man!
Yes its your opinion - but what I was getting it was your had that opinion from the start - sure the cars/crowd may not be as much as AJD(not sure wasnt there, Tiesto cocnert in VIC ftw!) but is it SCS's fault for people going around bad mouthing the show from the start and preventing people from entering? Same with the bling bling chromies and scissors doors - not my cup of tea either but you tend to get that at any car shows and the doof doof - people do that at car shows - livens up the atmosphere.
There was still a descent amount of entrants and spectators for me to go there with an open mind as usual and make an enjoyable day out of it :P
Oh yeah, there's no doubt it wasn't a decent day out! But yeah, SCS has attracted alot of negative comments and opinions.
It's worth it for what it is, though - and that's a free display of mostly tough cars! I think it's great that there's no entry fee or anything for the spectators.
these are the pics i have collected so far of my car (on my myspace) http://viewmorepics.myspace.com/index.cfm?...;albumId=914159
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
