Plenty of R32 GTST's have a problem where the climate control only blows hot air or cold air.
Even whilst cycling through the temperatures, the air doesnt seem to change.
First step is to check if everything is fine with your climate control;
Follow the below steps, if everything is fine, your problem might be the connection to the blend-door servo motor (read further below)
The r32 has a common problem of the Blend Door Servo Motor to stop working. This is due to the connection to the motor becoming damaged over time.
Solution;
- Go to the passenger foot well area.
- look up where the feet air vent is.
- There you should see a metal rod and a plastic clip.
If the rod has fallen off, clip it back into position.
- Cycle through the hot/cold temp buttons on the climate control quicky and check if you can see the metal rod moving. This rod controls the blend door.
- If the rod doesnt move, then the blend door servo motor is the fault.
- Just before the metal rod, is a wire loom connected to a socket
- Wiggle the wire loom whilst pressing the temp up/down buttons. The Blend door motor will then respond and move.
- I used some cable ties to create some pressure on the loom.
This is just a temp fix, and will not last forever..
Best would be to replace the blend door servo motor and/or harness.
Repair Guide:
If anyone has replaced their blend door servo motor, please post in regards to how difficult it was.
Hope this has helped some r32 owners with their climate control problems ;)
Cheers
Patrick
  • Like 1
https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/
Some information from _PhaseShiftDown, hope you dont mine me posting your information :)
Thanks Rekin for the pics, you're a champ m8 ;-)
Mine had the exact problem as you've described. The servo arm dosen't move when I cycle through cold and hot. But when I wiggle the plug while doing that, the servo arm moved. So I tried taping up the wires, pushing the wires upwards, and all sort of other things.... but still have the same issue.
Eventually I was able to find a fix, the trick is to apply a slight pressure on the actual plug towards the right (back of the car). There is a rectangular void on the left of the plug and all I did was stuff some paper in there to create that pressure and the problem solved. I was able to get cold air again!! Bloody awesome. Thanks Rekin!
And here is the reason why it was playing up, and I dare say the exact same fault with both yours and __PhaseShiftDown's cars as well.
piccies
You can clearly see where 4 solder joints on the back of the connector have broken away, one more looks like it is almost gone, and the last is showing stress.
Reflowed the lot with new solder and reassembled.
Easiest way I found to remove the module was to pull the radio bracket with the ac/heater controls out as well, and work through the hole. After you release the rod all the screws are on the top or sides of the unit, none underneath. Unclip the harness from the little jumper cable that is mounted on the top of the module, don't unclip the connection underneath until you have it out.
Didn't take all that long.
James.
Thats pretty much what I've suspected. Thanks for confirming heller44 -)
So there you go ppl with air con problems. Check this servo out before doing anything else. The paper can be used as a temp fix, but the best way is obviously re-do those solder joint.
piccies
James.
what is it meant to look like dude?
I don't really understand the question mate.
I have pulled apart the mixer actuator module and showing the broken solder contacts on the board-side of the plug, showing a pic of the plug connection from the outside, and a whole pile from the the copper side of the circuit board on the inside.
You are looking for dry solder joint (the silver spikes coming out of the PCB that are loose). In particular the plug pins that are soldered onto the PCB. If the solder joint is 'dry'. i.e. loose because the solder is getting old. Then it will disrupt the signal, causing the motor arm to become stuck.
So you basically need to 'reflow' the solder by applying a hot soldering iron to the dry solder joing and at the same time, add a little bit of fresh solder. Good as new again.
wish i had of known this when i had my r32...i couldn't figure out how to fix it...it was summer at the time and was only blowing hot air...so there's a hose (i think it may be a heater hose of some sort) that connects to a pipe at the back of the engine bay near the fire wall...i disconnected that and hooked it up to another hose and that gave me just cold air..then when i wanted hot air (winter) i reconnected the hoses
  • 1 month later...
got another question for you guess while your on this.
my climate control wont change from blow air from the vents ONLY. i cant change to demisters or footwells etc just the vents only :)
any idea?
Yep. There are two plugs on the climate control unit, if the left one isnt seated properly then the selection motor wont work. If you do the diagnostic you'll get numbers 32, 34, 35 and 36 flashing, this happened to me upon reassembling my centre console.
This writeup is great, thankyou very much for doing it. I pulled the actuator out on Monday, had a friend reflow the solder on Tuesday and re-assembled everything last nite. I finally have a working climate control unit. I'm totally stoked that I didn't have to pay mega bucks to get it repaired, cause summer is coming and I really wanted my aircon.
Only thing is, I had to remove the centre kick panel trim cause I couldnt see what was going on in the back. Now I've done it once I reckon I could do it again easily since I know where everything is and where it goes. If you're not sure, don't be afraid to try, just make sure you allocate a fair amount of time because when you do it for the first time there is a bit of a learning curve.
-D
  • 4 months later...
any idea?
just had this problem in mine
go to the drivers side footwell
look up under the dash and there is an actuator with one rod coming off it, the rod goes into some lever arms and there a like 4 while plastic bits with groves in them the black thing is the actuator that controls it
one of the cogs inside is prob broken
but in my case it had been replaced but the cog wasnt a good fir and bound up on the spindle
pull it out and have a look
you'll soon see whats going on
  • 1 month later...
Before I go ahead and open my unit up I thought Id ask.
What my car is doing is - I can turn on and change the settings on the control unit just fine but the actual "Fan" or blower doesnt seem to kick it or turn on and i end up with no sort of air blowing.
Any suggestions?
edit:
Just had a go with the auto diagnose.
Step 2 - displays 23 (water temp sensor but the car was dead cold then)
step 3 - displayed 31 (Vent mode faulty) and 36 (DEF)
So according to step 3 it means that the harness or the actuator is faulty so ill be pulling it out. Also while poking around the harness I could hear the actuator motor clicking and making some sorta noise. Could this mean that it indeed is the fault as described above in the posts with the harness and pcb?
but also does that mean that it will not blow any air of any sort at all? My issue was there when i purchased the car with it only blowing air into the footwell and eventually it just stopped blowing any air whatso ever.
Thanks
nish
Edited by Nishant
  • 4 weeks later...
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
    • Yeah good call, I will endeavour to tuck that down when I rewrap the looms it’s pushed up by
    • Good work. I will say, this line circled however, will potentially pool with oil, as it's going from high, to low, to high, before heading downwards.
    • Yeah, thumbsup from me. The distant shot of the bay just looks same-same as before.
    • Dad had a court case drag out with them from 1998 to 2004. He was in a not at fault accident, NRMA were the ones who covered the other person. They tried to blame his neck injuries on the fact he'd had an injury in 1981 on his extreme lower back where he slipped a single disc right near the bottom. Had been all cleared from that injury for years. This accident destroyed his shoulder, and f**ked a heap of discs in his neck, and he still has major problems with it to this day. Sarah's sister while on her L plates had a small Suzuki Alto, she had stopped to give way to an ambulance, and someone changed lanes behind her because there lane was also slowing, and rear ended her at 80km/h. (She had been stopped for a few seconds already too!). Car was completely f**kED. NRMA sent the vehicle around to 3 different workshops as they kept claiming "We believe it can be repaired, and not written off, we just need to find the correct workshop". It took 3 months, and a lot of arguing before they'd concede and wrote it and paid out. About two years later her sister had a Lancer, someone pulled out of a stop sign without stopping (in an 80 zone). Her sister swerved, hit the front of the other persons car (Instead of dead t-boning the drivers door), which ramped her Lancer, and made it roll multiple times down the road. It hit every panel on the way through. Her sister had slid her self out of the car, and remembers the ambos walking to the accident (They'd been sitting at a set of lights just down the road and witnessed it) and they were saying "Well, this ones going to be a fatality, no way you can walk away from that". Well, she did. And then NRMA sent two assessors out to look at the car, both of which wrote it off. They tried to send another assessor out, except a HUGE uproar was raised, and they FINALLY paid it out. That was on a car, that had damage to EVERY panel, you could see from 100m away the whole car was also twisted, roof bowed etc. Nah, we'll try get out of needing to payout on a $10,000 car... Her sister ended up with major shoulder reconstructive surgery being required, and was permanently limited in her ability to do her job as a nurse after that, as she can't (And was told before surgery too this would be guaranteed to happen) regain full strength in that shoulder. However, there was no choice to not have it, as she could barely use her arm, which was her dominant one, and was in near constant major pain. (And she's the type of person that would try and walk off a broken leg!) NRMA did the biggest run around on the personal injury side too for about 18 months, even to the point of trying to put 100% blame of the accident on Sarah's sister, even though the other driver admitted she didn't look, and didn't stop, and was charged by the police. Sarah used to have a Barina insured with them. It was a policy setup, paid all 12 months in advance. At the end of the 12 months, Sarah was living with me, I reviewed the renewal, it clearly stated "If you do nothing, your policy will cease on XYZ date". We did nothing, as we moved her insurance in with all of mine and I was with Shannons. We find out 10 months later, NRMA decided, because he DAD had a car insurance policy at the same address as what Sarah's mailing address was (Garaged address had been changed), that they'd put Sarah's (What should have been non existent policy) onto her Dad's month to month charges on his credit card. We had to jump through hoops, to get a refund. They didn't care that we actually found the letter that said "If you do nothing, your policy will cease" they made us prove we had NON COMPULSORY insurance else where before they'd issue the refund, and after they agreed to the refund, it still took another 6 weeks and 3 more phone calls for them to actually process it. They also had two insurance claims from storm damage, and they were an absolute cluster to get resolved as well (one vehicle, one house). Some how, up until about 3 years ago, her parents were still loyal to NRMA too, and we were like "How the hell are you so loyal to staying with them, when other places are so much cheaper, and they've f**ked you over every time you've ever had to make a claim?"
