heller44 Posted March 14, 2010 Share Posted March 14, 2010 (edited) I couldn't remember as it was a while ago, but looking at the pics it is easy.. closed open and then lift the rod out of the groove. Edited March 14, 2010 by heller44 Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-5132476 Share on other sites More sharing options...
Sarumatix Posted March 14, 2010 Share Posted March 14, 2010 Ya I actually unbolted it from the other end in my frustration. Which was fine.. until the gear slipped while I was resoldering. Now i'm mucking around trying to get the position correct again. I'd definitely recommend lock the gear in place before you do anything . Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-5132520 Share on other sites More sharing options...
soundtone Posted August 20, 2010 Share Posted August 20, 2010 Just another FYI. There is a plug in the centre console opposite the cigarette lighter. If that is unplugged the climate control will stay on hot. Thanks heaps Sarumatix! Turned out to be the plug in the center console giving me constant heat. I pulled my whole dash apart to fix the heater core and this is the one plug I forgot to plug back in. One side of the plug is attached to the same loom as the cigarette lighter. It has two wires, brown and green I think. Check this plug if you have been messing around with your dash. I'm so happy to get this fixed! 1 1 Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-5409060 Share on other sites More sharing options...
RBish Posted November 6, 2011 Share Posted November 6, 2011 my climate control will only blow hot or warm air. i then unplugged the cabin temp sensor and now it only blows ambient/outside air, anyway here is what i got from the diagnosis mode can anyone help? -26 = blend door fault. and my sensors 22.5 22.5 32 -30 checked the blend door and it wasnt moving with temperature settings so i unplugged it and cleaned the plug and refitted it and now the blend door actuator is working. so i think i just need a/c gas. Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-6097534 Share on other sites More sharing options...
SiR_RB Posted November 7, 2011 Share Posted November 7, 2011 looks like ur refrigerant temperature sensor is faulty as is mine ! but im not 100% where it is and how i go about changing the sensor Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-6098852 Share on other sites More sharing options...
RBish Posted November 11, 2011 Share Posted November 11, 2011 it actually ended up being my intake temperature sensor and not the refrigerant sensor, so i need to put a 5ohm resistor across the plug behind the glove box right? now my condensor fan never turns on so i decided to bridge the a/c relay and when i did i heard a clunk and the fan still stayed off. i was happy when i heard the clunk as something is engaging, so does anybody know what the clunk is and how to get the condensor fan working? Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-6105437 Share on other sites More sharing options...
heller44 Posted November 11, 2011 Share Posted November 11, 2011 Condensor fan? The one right out the front is an engine overheat emergency assist fan. Clunk is probably the clutch on the a/c compressor. Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-6105563 Share on other sites More sharing options...
RBish Posted November 11, 2011 Share Posted November 11, 2011 are you sure its an emergency fan as it looks like an aircon condensor fan Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-6105600 Share on other sites More sharing options...
heller44 Posted November 11, 2011 Share Posted November 11, 2011 http://www.skylinesaustralia.com/forums/topic/153378-r32-have-your-overheat-fan-turn-on-with-your-ac/ Nah definately not sure.. Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-6105810 Share on other sites More sharing options...
cobrAA Posted January 17, 2013 Share Posted January 17, 2013 I'm reading about a/c for about a hour now.. no one mentionned my problem ; Fan will only blow air at fan 4. nothing at 1,2,3. Have a clue what this could be? Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-6711602 Share on other sites More sharing options...
tj88 Posted November 20, 2013 Share Posted November 20, 2013 So hopefully someone can help me out here. Months ago i managed to wiggle the plug and get servo door to move to HOT. Now I've gone though and reflowed the solder (2 were cracked), which I figured would solve the problem. However I ran the diagnostics test and get faults 21,22,23,24,25,26,27 (every sensor), then get 30 indicating that the actuator is working, even though its still not moving when i cycle between hot and cold.Any suggestions? Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-7115433 Share on other sites More sharing options...
Chris Rogers Posted November 21, 2013 Share Posted November 21, 2013 I'm reading about a/c for about a hour now.. no one mentionned my problem ; Fan will only blow air at fan 4. nothing at 1,2,3. Have a clue what this could be? fan resistor - replace it. Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-7116618 Share on other sites More sharing options...
Chris Rogers Posted November 21, 2013 Share Posted November 21, 2013 So hopefully someone can help me out here. Months ago i managed to wiggle the plug and get servo door to move to HOT. Now I've gone though and reflowed the solder (2 were cracked), which I figured would solve the problem. However I ran the diagnostics test and get faults 21,22,23,24,25,26,27 (every sensor), then get 30 indicating that the actuator is working, even though its still not moving when i cycle between hot and cold. Any suggestions? try another controller. that would be a start. I do not see everything failing on that car. Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-7116620 Share on other sites More sharing options...
crutchs Posted December 17, 2013 Share Posted December 17, 2013 hi, new to the skyline world with a 32 gtst, my aircon is not working, it has gas, the system seems fine, it just doesnt blow cold, then i tested to see if it would blow hot air, it doesnt, so it only blows normal outside air, is there a way to open the system to only blow the cold ac air? or do i need to strip it down and resolder the switch, i looked to check the rod and it doesnt move Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-7146844 Share on other sites More sharing options...
Quigs Posted January 1, 2014 Share Posted January 1, 2014 very helpful info thanks for the write up. I'm currently looking for another r32 GTR and out of ten cars ive test driven only two have working air conditioning. (ie blows cold air and work through all the different cycle's, operating modes and correct temperature. Just as a FYI i got a quote to convert R12 system to R134a for an R32 GTR. Looking between $1000-1500 for drive in drive out with a brand new 134 suitable compressor, lines, new seals labour etc Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-7157879 Share on other sites More sharing options...
Marko R1 Posted March 12, 2014 Share Posted March 12, 2014 Hi guys, I just had my a/c regassed with r134a on my r32GTR and it works very well. The mechanic questioned why the a/c does not run when the a/c is turned on...we tested the relay and that is fine and checked all the fuses. Apparently it's quite dangerous to run the a/c without the fan as the pressure can build high enough to explode. My question is what triggers the electric fan, is it the a/c or the engine when it gets too hot? Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-7225570 Share on other sites More sharing options...
heller44 Posted March 12, 2014 Share Posted March 12, 2014 See post 47/49.. Educate mechanic. As long as the engine is running the engine fan will be pulling more than enough air past the aircon section. If the engine isn't running you don't need to worry about the aircon.. 1 Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-7225601 Share on other sites More sharing options...
Marko R1 Posted March 12, 2014 Share Posted March 12, 2014 Thanks and funnily enough I did the diode mod as mentioned in the above posts on my previous gtr...I'm losing my mind See post 47/49.. Educate mechanic. As long as the engine is running the engine fan will be pulling more than enough air past the aircon section. If the engine isn't running you don't need to worry about the aircon.. Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-7225612 Share on other sites More sharing options...
KostaGTR Posted February 23, 2015 Share Posted February 23, 2015 Does anyone have a photo of the fan resistor? As my aircon turns on but doesn't blow air out of the vents... From what I can gather from reading this it must be fan resistor Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-7485515 Share on other sites More sharing options...
Scott Black Posted March 22, 2015 Share Posted March 22, 2015 Hi guys, I just had my a/c regassed with r134a on my r32GTR and it works very well. The mechanic questioned why the a/c does not run when the a/c is turned on...we tested the relay and that is fine and checked all the fuses. Apparently it's quite dangerous to run the a/c without the fan as the pressure can build high enough to explode. My question is what triggers the electric fan, is it the a/c or the engine when it gets too hot? then the mechanic is a dipshit, it can be modded to come on with ac, and that will improve ac performance expecially at idle conditions, However it will not explode, there is a high pressure cut out switch (normally part of the low pressure cut switch to) and if he gassed up a car that doesnt have one, then hes not doing his job properly as its part of the code of practice for automotive ac, and guess what the high pressure cut out switch does long before the presssures get high enough to burst a hose.....it turns off the ac Link to comment https://www.sau.com.au/forums/topic/236745-r32-airconditioning-not-working/page/3/#findComment-7501549 Share on other sites More sharing options...
