Does anybody know of anyone who makes a panel to fit into a slot in the radio section of the dash to accommodate gauges? Like the ones in autechs. I want something to fit a few small autometre gauges in there.
Was going to make up something nice out of some polished aluminium but if something already exists that would suit my current motivation level a whole lot better :P
https://www.sau.com.au/forums/topic/236764-single-din-gauge-holders/
Hmm.. I brought my din insert from egauges.com it was about 20 bucks US and fits ok (depends on where you put it) - I've got mine at the bottom (so climate control, stereo then gauges)....you will need to file/sand down the holes a little bit more to fit the gauges (52mm) and if you are going to put it in the middle slot then you will need down sand down the back of it as it extends a little bit...i'll get a pic up on here - my gauges stick out a from the facia (I don't want to cut up the surround to flush mount it
It's really much on what you want to do and what size you want to go?? Polished Aluminum would be nice but the shine in the sun would be annoying and potentially dangerous
Yeah the shiny-ness was the only thing worrying me. That would be good if you could post a quick pic. I found these ones on ebay..
http://cgi.ebay.com.au/NEW-single-DIN-trip...idZp1638Q2em122
Is your's similar to that? with the staggered sort of layout. Can't really go wrong for that sorta price
52mm gauges are too big to neatly fit within a DIN space.
the cleanest solution is the defi DIN gauge unit. stand alone three 40mm gauges,two temps and one pressure. available in green,white or red. if you're in Sydney, revolution race gear have one in red in stock atm,$550 if I remember right.
my girlfriend has one in the dash of her ae111. works very well.
Justin...
Justin...
I got a piece of 4mm perspex, cut it to fit single Din space, then drilled three holes for the gauges. Too easy.
You will hve to open up the holes a tad. Get a drill bit with a rotary burr on the top of the shank.
Mine is in the middle slot.
Justin...
Not necessarily true, I managed to get my Defi's in there and it looks OK - not perfect, but most people don't notice that they're not perfectly spaced out.
I would have gone with the Defi DIN cluster, but you can't specify which meters will go in there, so I went with separates so I could choose to my needs.
I got an off-cut of Poly-Ethylene from a plastics mob here in Sydney, and it cost me nothing, luckily! My old man and I measured and trimmed it down, and got a hole-saw to cut the holes, which took quite a bit of time. Another problem is that it's impossible to find a 52mm hole-saw, so like Hugh mentions, you have to file or burr the holes out until the gauges fit. Keep the holes a bit tight too, that way they won't budge while you're driving, and will be much harder to steal if anyone should ever attempt it. I made some small brackets for the back to secure the gauges to as well, just as added protection.
Mine is just like that
You'll find the angled ones don't quite fit properly and most likely you need to trim the fascia to make it fit.
fergo308 - while the defi dim gauge set is good - the major problem is that you only get two temps and a pressure....nothing else...I've got boost, oil temp and volts.
Goldzilla's idea is pretty much the best way to fit 3 gauges on there (i've got mine the setup like that but the other way around - gauges on the bottom and stereo above.
  • 1 year later...
sorry to bump old thread, but im just wondering, goldzilla, before you fitted these gauges, you supposed to fit a panel for your alpine 9833? like the one surrounding the head unit to cover the holes? can you still fit that in anyway so it will look so much better?
Can't do it, unfortunately, as the surround that came with the head unit is too big to fit between the dash surround as it is, and too fragile to cut down to squeeze in there... It'll probably break as I try to trim it.
The Defi Din gauges are really good. but because it's two temp and and one pressue - it's of no value for me...Maybe down the line when i'm sick of my gauges and decide to mount my boost gauge somewhere else
David (Airbox) looks very neat...is all the gauges working and was it a pain to install??
all guages are working, I just need to fit the oil temp sensor, which I have, but am waiting until i fit an oil filter relocation kit. It was pretty straightforward to fit once I had worked out the wiring, had to file the stagea cage a bit and cut off the lugs which were attached to the guages.
Edited by airbox
    • Yeah, they look good. I should try to fit them on mine. But being a GTSt, the guard shape probably doesn't suit properly.
    • Nah, it's not a simple voltage divider. I'm not enough of an electronics guru to know how they make these circuits work. If I had a better idea of how the ECU's temperature measuring is done, I could then actually do as you want, which is turn that resistance chart into a voltage chart. But my approach has not worked. What I did was interpolate the sensor ohms values for the temperatures you listed, as you did not have any of them on a temperature ending in zero or 5. These are: °C ECU V sensor ohms (interpolated) 58 2.68 11.85 57 2.7 11.89 56 2.74 11.93 54 2.8 12.01 49 3.06 12.208 47 3.18 12.284 43 3.37 12.42 I then assumed 5V supply to the resister and calculated the voltage drop across the sensor for each of those, which is just 5 - the above voltages, and then calculated the current that must be flowing through the sensor. So you get:             Values in sensor °C ECU V sensor ohms (interpolated) Supply volts Volt drop Current 58 2.68 11.85     5 2.32 0.195781 57 2.7 11.89     5 2.3 0.19344 56 2.74 11.93     5 2.26 0.189438 54 2.8 12.01     5 2.2 0.183181 49 3.06 12.208     5 1.94 0.158912 47 3.18 12.284     5 1.82 0.14816 43 3.37 12.42     5 1.63 0.13124 And then use that current and the ECU's sensed voltage (which must be the voltage drop across the in ECU resister is there is one) to calculate the resistance of that in ECU resistor. You get:             Values in sensor   Other resistor °C ECU V sensor ohms (interpolated) Supply volts Volt drop Current   Volt Drop Resistance 58 2.68 11.85     5 2.32 0.195781   2.68 13.68879 57 2.7 11.89     5 2.3 0.19344   2.7 13.95783 56 2.74 11.93     5 2.26 0.189438   2.74 14.46381 54 2.8 12.01     5 2.2 0.183181   2.8 15.28545 49 3.06 12.208     5 1.94 0.158912   3.06 19.25592 47 3.18 12.284     5 1.82 0.14816   3.18 21.46325 43 3.37 12.42     5 1.63 0.13124   3.37 25.67816 And that's where it falls apart, because the resulting resistance would need to be the same for all of those temperatures, and it is not. So clearly the physical model is not correct. Anyway, you or someone else can use that information to go forward if someone has a better physical model. I can also show you how to interpolate for temperatures between those in the resistance chart. It's not fun because you've got to either do it like I did it for every 5°C range separately, or check to see if the slope remains constant over a wide range, then you can just work up a single formula. I'm just showing how to do it for a single 5° span. For the 58°C temperature, resistance = 11.77+2*(11.97-11.77)/5 The calc is a little arse backwards because the resistance is NTC (negative temperature coefficient), so the slope is negative, but I'm lazy, so I just treated 58 as if it was 2 degrees away from 60, not 3 degrees away from 55, and so on.
    • Um.... This is not easy. I will have a fiddle with it, but make no promises. I think, given the explicit resistances vs temperature, and your ECU measured voltages, it should be possible to match them up. I will do that by assuming a 5V supply from ECU to sensor, find out how much current would have to flow to produce that voltage, then use that current as a .... nah f**k. That won't work. The supply voltage is fixed, but there's nothing to say that the ECU regulates the current too. Um... I dunno. I guess there's a voltage divider setup in the ECU. As in, there's another resistance between the ECU's sense terminal and ground. That way, as the sensor resistance changes, that's how they get a floating voltage that varies with the temperature, without having to control the current. Give me a minute or 3.
    • *that* is a question for chatgpt (or someone that understands maths....but I'd try chatty). Drop them the table and ask for the formula
    • Alright. Exhaust has been looked at, and booked in 'soon'. I'm not 100% convinced it's going to be as good as possible but I'm going to go with it anyway. If I get a reasonable thing that works for 10 years I mean that's twice as long as I've lived with the current one. I have a more pressing issue. I have fixed my MPVI3 (by buying a new one). Excellently, one can wire in analog 0-5v inputs to the ECU itself. I had wideband already via Serial so I also wired it in via the direct input. The idea being I can use the standalone logging without a laptop and have Wideband data in it. The other wire I thought I'd use oil temp. This is where I've gone crazy. HPTuners requires you to implement a formula so you know how much volts = how much temp. This seems relatively simple to me. However I cannot find the scale for this anywhere on the internet, nor decipher how to figure it out without removing the sensor from the car. All I know is that voltage actually goes up as temperature goes down. I am using the actual gauge, so I can see what the temp is. The signal wire has been branched off into the MPVI3. EXAMPLE: 2.68v = 58C 2.7 = 57C 2.74v = 56C 2.8V = 54C 3.06V = 49C 3.18V = 47C 3.37V = 43C I think the gauge is 50-150C. It may be more. It may be less, because I can't find it for the love of f**k. It appears all the information about the gauges I have has been scoured from the internet, but the sender is VDO 320.021 I believe the resistance chart is this How the f**k do I convert this to a voltage? Once I have a voltage... I then have to perform this transform of said voltage to show it in the scanner: https://www.hptuners.com/help/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm @GTSBoy you're probably my only hope here TEST YOUR MIGHT
