have had a towbar and wire plug fitted.was then told that with this model of car the indicators draw too much current when you have a trailer or caravan connected,so would have to replace caravan indicator bulbs with led.have done that and at least the indicators work now,but very faint. ha s anybody overcome this problem? any help/comments most appreciated.
https://www.sau.com.au/forums/topic/236806-v-series-towbar-wiring/
ok - if you were QLD based I was going to tell you to come see me.
I would find a autoelec used to working on BMW/benz as those cars sort of follow your rules.
the idea on what I have said is to switch current off the battery supply rather than the acutal lights. you use the lights to trip the relays.
You need something called a power converter - attached is the Infiniti TSB that talks about it (G35 = USDM version of our V35 Skylines). Basically it is a box that contains the relays which Chris refers to.
Not sure where you can get these in NZ - maybe Supercheap/Repco?
As Chris notes somebody who works with Euro cars can probably help.
Where did you get your towbar fitted and what did it cost? Been meaning to get one fitted to my 250GT for a while now...
If you get this sorted can you post up here again - useful info for the Auckland dwellers... :(
ITB04_020e.pdf
that in reality gives MORE than enough info to make one.
go to jaycar and get:
5 transistors (BC337 will do)
5 10k resistors
5 diodes (1N4004 will do)
5 SPST 12v relays (12v coils)
and build 5 separate circuits using the transistor and resistor to drive the relay . the diode is there for spike protection from the relay coil
see here for the concept:
http://www.jaycar.com.au/images_uploaded/relaydrv.pdf
you need the first one
background here
http://www.kpsec.freeuk.com/trancirc.htm
from there Download the data sheet on the BC337
http://www.datasheetcatalog.org/datasheet/...ips/BC337_3.pdf
pin it out and away you go.
the OE lights fire the transistor (draw on this is WELL below the spec in the nissan sheet posted above.) that in turn fires the relay and sends 12v to the auxilary lights (IE trailer.)
theres my $1 worth on this topic :(
holy crap,thats too much information,im a chippy not a diode soldering type person.!! the tow bar was manufactured and fitted by ackerbilt in penrose,nice tidy job but i obviously cant recommend their wiring!!.it cost $490.00 all up.will post again when this is sorted.thanks people for your help.
Cheers for that Chris, wish I had time to whip up something like that...
I'm guessing you should be able to get something like that from an auto sparky who knows what they are doing. I know a good one in Pt Chev - Ron Wood auto electrical. Not sure if he has these modules, but he knows what he is doing so might be able to help.
Will keep my eye open for one of these modules - shouldn't be too hard to come by these days.
Ant,
thing is with these cars I have to make things like that. I have found if you upset one of these cars it will stay mad at you for a LONG time. the later cars ('04.5+ ) are straight CAN and really do not like being fiddled with.
background is electronics eng. mixed with autoelectrics.
find someone who has a electronics background they can knock that up in no time. (I'm in the midst of doing one now for a car.)
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
