Hey,
Unfortunately most workshops are closed on Saturday or don't answer there phone, so I'm wondering if I could get some advice from the forum members.
EDIT: read $350 - 400 is normal for fitting a new clutch.
My twin plate OS giken has started slipping quite badly, anything below 3K RPM in 4th gear makes strange sounds while driving, you can rev upto 3K RPM in 1st and wait >0.5 second before the car starts moving, and it all gets worse if you keep driving the car.
So, I've done some research and Jim Berry used to rebuild twin plates OS giken's for about 1100 and machine the fly wheel.
I use the car for street and a light track day, I don't drive it hard off the track (often anyway), and I only do the very occasional track day so it would be more like 70% street.
I'd like my clutch to slip a little more than the OS giken did but I'm a little short of $$$ right now so I'm happy to put up with it if the price is right.
Car is making 250RWKW, but in 6-12 months I want to reach about 320AWKW....and keep the same clutch.
I am unsure which OS giken it is, its grab point is right near the top and when it was working it preferred to be launched at 3K RPM otherwise it would slip and grind and rattle....
I am not overly concerned about the twin or single plate clutches, I just prefer a clutch with a little more slip and a reasonable price...
EDIT: Please feel free to recommend other workshops that rebuild clutches, in Vic or elsewhere :)
Thanks,
Gareth
After reading clutch housing explosion I'm starting to think maybe I should go for an anti-burst cover AND re-consider my choice of clutch.
Any recommendations?
Jim rebuilt a stuffed second hand single plate Nismo clutch i sent him. Its an awesome clutch; very drivable, reletively light under foot and fairly cheap to do. Holds onto 350rwkw no worries.
He could rebuild your twin no worries i expect.
Shaun.
greenline.jp ~$800-900 delivered (7-10 days) for new OS Giken discs x2, pressure plate and the middle plate, then just get the flywheel machined $50-70
Not a bad price, if they can deliver in 7-10 days that's pretty reasonable, especially compared to the bad stories I've seen about nengun.
I'll check it out after giving NPC clutches a call about a rebuild, and trying to track someone down in Melbourne.
Only issue with buying off Greenline is I'm not quite sure which exact model I have...
Keep the suggestions coming :(
My OS Giken wasn't easy to drive, but its a solid clutch OR it was already gone when I got the car.
Anyway, I was pleasantly surprised by NPC's rebuild price, if it was quoted correctly its below $800 and I'm getting it rebuilt soon....just need to find a workshop that doesn't mind a 1 week wait for the rebuild :)
Thanks, rebuilding sounds like the way, its very difficult to find a workshop that doesn't mind the car sitting around temporarily but I think I've found one in Vic :cool:
  • 3 weeks later...
Just FYI for anyone reading, the clutch actually ended up been a Nismo twin-plate, the model before the super coppermix.
And the transfer case was the problem with the slipping, there was nearly 2mm left on the clutch itself.
The clutch is getting rebuilt and I've been offered a transfer case (cheap) and one from the workshop, I've gone with the one from the workshop because I know its in good working condition :D
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
