Wrecking a complete car in melb
r33 gtst series 2
sold items are:
headlights
bonnet
front bar + rio
driver side windows switch
center console and dash fashia
items avaliable are the rest of the car
engine and gearbox manual 80k km inc computer = $3000
front calipers and rear brakes and calipers inc discs ABS= $600
rear end complete abs = $500 inc clipers and brakes and cradle
cluster =$200
doors complete motor window and reg door hangle and lock= $260 each
rear window = $150
side 1/4 windows tinted dark= 80 each
boot lid inc spoiler = $200
3 inch exhaust from front pipe steel inc cat near new $400
18 inch gold pro N1 BLACK RACING rims with bridgstone s03 235 40 18 tyres with 60% tread on em $1000
rear tail lights = $200 pair
skyline garnish $70
rear bar = $80
complete boot carpet and side trims = $150
complete seats inc door trims = $400
mirrors = $50 each
parcel shelf = $50
interior carpet $80
seat belts = $ 150 set
roof linning = $60
sunvisors = $50 pair
front steering rack = $100
front k frame complete $150
front hub assembleys = $150 each side
left and right guards $ 100 each
side skirts $ 150 pair minor crack on one not on visable section
rear pods 400r i think $100 pair
indicator stalk = $50
steering coloum $ 70
panel cuts also avaliable
pedal box = $100
cluch cyclinder $ 70
brake cyclinder $70
brake booster $70
climate control unit $80
front floor mats $40
heater air con box complete $ 150
dash no air bags $80
steering wheel immac no airbag $60
condenser $50
if there is anything not listed just ask for it i will have it for sure
Pick up in reservior call 0402090079
all items must be sold all prices are negoable no stupid offers please want to make someting back on my loss
Edited by SXC_R33
  • Replies 87
more than welcome to come look at the rims but they look good on the car i can get some pics up later 18x8 +38
cheers in advance for pics, may be able to come have a look tomorrow
r33 gtst series 2
sold items are:
headlights
bonnet
front bar + rio
cluster =$200
rear window = $150
skyline garnish $70
rear bar = $80
mirrors = $50 each
parcel shelf = $50
interior carpet $80
roof linning = $60
pedal box = $100
brake cyclinder $70
brake booster $70
condenser $50
hey buddy wonderin if youll sell the windscreen..?? cheers..
You got s2 steering wheel that has airbag that been exploded? If so i'm after the plastic bit under the wheel.
And you got the surround that covers the steering column between wheel and dash?
PM me the prices.
Cheers
Grant
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
