hey guys dunno if any of u guys have ever had this problem
but suddenly 2day my car wont get boost above -5
i haven't been using the car
but have removed my fmic and installed a stock smic
just wondering where could i have possibly gone wrong or what else could have happened
grrr
want boost back
https://www.sau.com.au/forums/topic/236840-losing-boost/
Does the car idle fine? Or does it hunt around a bit? Get some one to rev the car in neutral and stick your head near the SMIC and listen if you can hear a leak. If the intercooler is the only thing you have touched, then your problem lies there.
https://www.sau.com.au/forums/topic/236840-losing-boost/#findComment-4145073
oh ok
so thats good
i was kinda thinking for some reason i coulda poped my turbo
but thats unlikely right?
i do rev it up to about 4.5k when i turn it on sumtimes just to check it was working when i installed the intercooler
but didnt pay attention to the boost at that time
but thats unlikely to have cause it right?
so more than likely its the piping not completely sealed?
any tips on sealing the pipes really good?
https://www.sau.com.au/forums/topic/236840-losing-boost/#findComment-4145361
wat u mean rags?
is it likely at all that the smic is damaged?
by damamged i mena have a hole
If you had a hole, like a decent one in the SMIC, you'd have more dramas then no boost. It would be like trying to run with a cooler pipe off...
Rags, as in CLOTH...
Pull it all off, check pipes for blockages etc.
If you're only seeing MINUS 5, on the boost gauge, you're not even hitting atmospheric pressure, IE, you can't flow enough air through the pipes to even satisfy the engine if it were normally aspirated. You don't have a hole in the pipes, you have a blockage somewhere.
Either that, or have you taken the car for a drive and tried to boost it?
https://www.sau.com.au/forums/topic/236840-losing-boost/#findComment-4146007
nah the car has no rego atm
so cant take it for a drive but when i rev it up a lil...it goes from minus seven up a bit then drops down a bit agen
and stays at that point
so its likely i have a blockage or leakage sumwhere?
https://www.sau.com.au/forums/topic/236840-losing-boost/#findComment-4146650
just reving it normally can bring up boost
or am i wrong and imagining things?
On the stock turbo i think you can bring it onto a little bit of boost, 1-2psi, but most cars with a larger turbo you can't bring it onto boost without putting it under load.
https://www.sau.com.au/forums/topic/236840-losing-boost/#findComment-4149691
well there is your problem lol
the car needs to be under load to create boost.....
take it for a drive....
Agree'd but you would still be able to hit 0 and should be eaisly able to pass -5... check for obstructions.
https://www.sau.com.au/forums/topic/236840-losing-boost/#findComment-4150038
Depends how hard you're prepared to rev it and for how long to make boost...
Take it for a drive, you're most likely imagining things, and nothing is wrong.
https://www.sau.com.au/forums/topic/236840-losing-boost/#findComment-4150392
