Currently wrecking an R33 series 2
All parts are in perfect condition unless otherwise stated. Large parts pickup only. Small parts, will post at buyers expense. Located SEQ (Ipswich).
To contact, please call 0413 863 207 OR PM :)
RB25 AAC Valve - $60
RB25 Actuator - $35
Stock RB25 BOV, bleed hole welded for constant boost - $45
R33 series 2 bootlatch key included!! - $40
R33 boot gas struts & hinges - 2 PAIR! - $40 each pair
R33 series 2 instrument cluster - $100
R33 series 2 instrument cluster dash surround - $15
Full R33 SERIES 1 dash surround, including gear stick surround & cigarette lighter, needs paint, no cracks - $60 the lot
R33 doors, left & right, white - $150 each
Fuel cap & boot release mechanism complete - $25
R33 series 2 rear garnish, white - $25
R33 chrome door sils with nissan emblem (pair), extremely rare factory option
R33 GTR centre console gauge cluster, carbon finish - $100
As brand new Rear only HSD coilovers to suit R33 - $350 the pair
Tail lights - $60 each or $100 the pair
R33 RB25 series 2 engine loom - $150
R33 non-ABS brake master cylinder - $80
R33 rear view mirrors, left & right - $60 each or $100 the pair
R33 power steering reservoir - $20
R33 radiator, no leaks - $100
R33 series 2 stalk controls - $50
R33 series 2 steering column surround - $20
https://www.sau.com.au/forums/topic/236873-parting-out-r33-series-2-with-pics/
R33 series 1.5 airbag steering wheel - EXCELLENT CONDITION!! - $200
R33 series 2 washer bottle complete, pumps & cap - $30
R33 rear brakes including rotors, calipers and pads - $200
Other miscellaneous items
- Full series 2 coupe carpet - excellent condition - $100
- Full roof lining, including visors and lights with switches - excellent condition - $100
I have a few other random parts, I may have what you're after so ask! To contact, please call 0413 863 207 OR PM :)
im interested in the center GTR cluster as my new head unit is smaller than my last and i will have a gap
and possibly the boot release as mine is broken
will PM you once i pull apart my car to have a look at why the boot release isn't working
  • 4 weeks later...
hey ill take: R33 series 2 steering column surround - $20 and your b pillars of the outside of the car if they have all the clips and not broken.. thanx..
would you sell the gear surround by itss self for $30?
do you have the surround that is on the drivers side door switches?, i just need the plastic surround, no power window switches.
  • 4 weeks later...
has the steering surround gone? what is the top of it like condition wise?
Do you have the driver's side a-pillar cover that runs from top of dash around top of door frame to B pillar?
steering surround still here. perfect condition.
Polish and psi. both those parts are gone.
sorry I havnt been in here for a bit.
  • 3 weeks later...
  • 2 months later...
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
