White Passanger Door with glass and regulator.(No Mirror) Has some paint scraped off $100
R33 Passanger Side Mirror $40
White Series II Bootlid with Spoiler $100
Black Series 1 (Non MSepc) Nismo Style Front Lower 1/2 Spoiler $200
ABS Unit $100
2 Standard caster rods in great condition $60 Both
Front Steering Rack and Cross member. Drivers side rack end bent $80
Passanger Side Hub $40
Series 2 Coupe Door cards in Excellent Condition $100
Bride/Recaro Rail Drivers Side Rail $100
R33 GTS-t Std Airbox $50
Manual Pedal Set $100
RB25det crossover pipe with blowoff valve $50
Rb25det U-bend off the Turbo for intake $50
R33 Bonnet Release Cable $40
R33 Series II CAS $80
Handbrake Handle with Leather Handle $40
Handbrake Handle without Leather Handle Including Cable $60
Edited by Brokenz
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
