Boost Fx Dual Port Bov
Item:Boost FX blow off valve. 3 BOVs in one.
Condition: brand new
Price:$170 or trades
To Fit: universal! comes with an adapter that can be welded on to anything
Contact: 0431731083
Comments: off the hook!
Colour: i got one of each atm. Only need one LOL
"The BOOST FX Dual Port blow off valve is 3 valves in one. It can be configured to vent pressured air back into intake for a quite system, straight through to the atmosphere from two ports for a supersonic sound or even both! With the flexibility of this blow off valve, there is an application for every use. From a daily drive to a full race or drift car, BOOST FX will guarantee better performance and durability from your turbo.
Fully adjustible
With a twist of a wrist, the BOOST FX blow off valve will allow you to adjust the pressure spring within valve's piston to control the flow of pressure until the valve is released. For instance, if the pressure spring is adjusted to hard (down), more pressure is needed to push the piston and open the valve allowing the air to vent. This happens in hard revving or high RPMs. While adjusted to soft (up) less pressure is needed to push the piston therefore allowing the blow off valve to vent air more quickly and easily even from low RPMs.
Superior exhaust port
The delta port design helps vents pressured air from the turbo faster, relieving the stress from the turbine whilst retaining mechanical strength and integrity.
Compact Design
Super slim design to fit into any area in any car whilst maintaining maximum performance.
Special Viton sealed piston
Unlike any other the BOOST FX extreme condition Viton "O" ring is used on the piston of the blow off valve to give 100% "unleakable" seal to the valve even at maximum pressure. This reduced the spring force required to keep the valve shut. The lower the spring force the faster and more effective the valve.
Kit comes with:
1x any colour BOOST FX blow off valve (please specify when purchasing)
2x BOOST FX trumpet
1x BOOST FX plumb back trumpet
1x BOOST FX cover plate".
Got a black one aswell n haven't got the pictures for the adapter but its another piece that bolts at at the bottom with an allen key.
  • 3 weeks later...
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
