And I've actually heard from a friend who did that setup on his VS V8 commy that it can be beneficial as the air that passes through the turbo is alot cooler when it goes through since its got that extra distance to travel. Not too sure on the validity of this point but it kinda makes sense...
How does it defeat the purpose? The car is still turbocharged...
well, the idea of a turbo charger and heat, is so the exhaust gases are hot and "excited" and spool the turbine a lot faster than the much cooler low flow of air at the back of the car.
The response out of one of those setups would be terrible. Plus they have a hell of a lot more pipe distance to cause leak problems.
  • Replies 52
Im buying a 6boost manifold atm with a gt35R (0.82) atm and will be expecting full boost around 4300, a little laggy for the rb25 but i am planning to convert to a rb30 down the track so its not a bad option, if you want in a few weeks when its installed up i'll let you know how it is on the street
Ive read everyones comments, aswell as researched the idea and the conclusion will be
a.] GT3540R w/ 0.82
or
b.] GT3037R w/ 0.63
ive read alot about these turbos on different setups and depending on what Im gonna pursue ill will pick the turbo that will suit it.
It'll only leak at the joins but every car has that.
As for the cooler air flow causing lag, we're talking about mostly V8's that do this setup not skylines. Obviously its dumb to set it up on a skyline but you wouldn't need to. A big v8 needs the lag so it doesn't smash tyres. Get the v8 going then boost, can't beat that.
None of that makes any sense at all
I has a dream!!
Im gonna buy a stock turbo and replace my rear muffler with it!!
Rb25dett baby yeah!!!
would surely make 11ty million killer wasps at 35rpm and then ill use one of those ebay electric superchargers to really get it going down low
*imagines pipe work needed to run a single AFM with a turbo in the stock spot, one at the rear, 2 intercoolers while using PVC for piping*
Do you think Ill win a Engineering award at Autosalon?
P.s Im not drunk
:cool:
Btw, Ive concucted a flange to attack my Stock RB25 turbo to my ride on mower , ill be using a custom intercooler w/ no BoV, hopefully producing some mower dose action. I got the idea of a Youtube vid of a guy doin it, should be fun. I hope i dont blow up the engine as its gonna be 100% FF.
I love the fact that that a guy with the initial thought that he would high mount a stock turbo thinks he has the skill / money to turbo his ride on with a custom cooler!!! ahahaha
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
