If it's the one I did up for the SAU stickers then that's Myriad-Roman.
I'm down for stickers + shirt! Wondering can I get other stickers done up too? Wanting to get a couple of East Bear stickers done up.
Send me through the sticker you want done, see what I can do.
tell me bout it,
good to see he kept going with speedway!
Dont even mention speedway lol, we live, breath and eat the bloody thing now!!! Were in Scotland at the moment for his racing!!
Alrighty boys and girls, I have ordered the coloured sheets to make shirts.
Can you guys between you think of two designs you would like me to make.
I can put your usernames on the shirts.
I will make them as soon as there is two designs you all like and my order has arrived.
Was thinking $20 for each shirt....is that ok with everyone???
***One thing*** You wont recieve shirts until november as Im still in Scotland so payment wont be nesasary until then, Ill arange to meet up with you all sometime...If your real keen I can post shirts from here for $25.
A few of you were after polo shirts.....can do them but they might be a tad more then shirts... will look into it this week. So its up to you lot to design two shirts now, Play nice :banana:
Jasmin.
Jasmin.
are you able to get measurements of the shirts ?
ill happily order 1 or 2 :P
ill happily order 1 or 2 :banana:
Hmmmm, they just say 97-102cm for the medium.... thats the only size I have right now. getting the rest tomorrow.
Jasmin.
Create a poll with the designs that have been made!
Can do the one Vu made, just the url doesnt look so good in real life, the front is good I think thats a definate. someone think up another design so we have two definate, if more designs then two get made up then Ill do a poll
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
